20 Most Recent
Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator Questions & Answers
Leveling refrigerator
In a Home the recommended level (front higher to back lower) is 1/4" (Right to Left - level)
Never less than in order to allow door to shut own their own, but there is nothing wrong with having a perfect level refrig if everyone closes the doors properly which they won't. A refrigerator requires to be reasonable leveled to avoid compressor fatigue. In a Motorhome people can't always find level ground, so it quite frequent that their refrigerator burns up when running. From that experience I'd say I would level any fridge which is over 1/2 inch off.
6/8/2019 10:41:19 AM •
Maytag...
Answered
on Jun 08, 2019
Water will not dispense.
have you try replacing the water filter if that does not help check your water solenoid valve.
6/3/2015 3:57:40 AM •
Maytag...
Answered
on Jun 03, 2015
Maytag refrigerator not cold.
do you have a full frost pattern (coating) on freezer coils or see a ice ball, if ice ball Leak in system or bad valve in compressor. not worth fixing. go on (repair clinic .com).
you have a dampener and a fan to let the cold air go to all the areas check to make sure fan is running push in light switch in freezer and llisten for fan could be problem or no power to fan from main control board.
Dampener is flapper door that lets cold air from freezer go into ref. section
are your doors sealed, gaskets, frapper between door on ref section closing.
also your return air ducts need to be clear of ice, is your ice maker working that means that it is below 10 degees and repairable.
5/4/2014 1:06:00 PM •
Maytag...
Answered
on May 04, 2014
