20 Most Recent
Fujifilm Finepix Ip-10 / Ip10 Digital Camera Photo Passport Picture Printer Questions & Answers
In my fuji frontier 370 error 2503 and w2411 is coming
The "W" indicates that it is a recoverable error. The "24" indicates that there is a problem in the paper feeder. The "25" indicates that it is a laser printer problem. Looks to me as though you have a paper jam.
2/13/2024 7:57:44 AM •
Fuji Cameras
Answered
on Feb 13, 2024
Sensitive Command Dial on Selector Button.- S9800 Finepix - any ideas what's wrong?
If the command dial on your Fuji Finepix S9800 camera is overly sensitive, making it difficult to select items on the menu or adjust settings, there are a few steps you can try to address the issue:
- Clean the dial: Sometimes, dirt or debris can accumulate around the command dial, affecting its sensitivity. Use a soft, lint-free cloth or a small brush to gently clean the area around the dial, removing any particles that may be causing the sensitivity issue.
- Adjust the sensitivity settings: Check the camera's menu or settings to see if there are any options to adjust the sensitivity of the command dial. Look for settings related to "dial sensitivity" or "control dial response" and experiment with different levels to find the one that suits your preferences.
- Reset the camera settings: If the sensitivity issue persists, you can try resetting the camera settings to their default values. Look for the "Reset" or "Factory Reset" option in the camera's menu and choose the appropriate setting. This will restore the original settings and may help resolve any software-related issues.
- Contact customer support: If none of the above steps resolve the sensitivity problem with the command dial, it may be worth contacting Fuji customer support for further assistance. They can provide specific troubleshooting steps or advise you on whether the camera needs to be inspected or repaired by a professional technician.
It's important to handle the camera with care while attempting any adjustments or cleaning. If you are unsure or uncomfortable with the process, it's recommended to seek professional help or take the camera to an authorized service center to avoid any potential damage.
6/18/2023 4:43:48 PM •
Fuji Cameras
Answered
on Jun 18, 2023
Camera fault
Check batteries and the terminals that connect to your batteries. Often the contacts get corroded because batteries have acid in them.
8/13/2019 10:01:32 PM •
Fuji Cameras
Answered
on Aug 13, 2019
