Remote that came with tv wont work
I stumbled across this page while the owner's manual for my remote was lost. I've now found the manual (after not having any luck finding the solution on the web)!
The AKAI KC02-D2 remote operates my AKAI PDP42Z5TA 42" Plasma HD Television. It may work with others as well, but that's the TV I use it for. If the batteries are removed (or dead) for a while, it will lose its programming. Here's how to reprogram it.
AKAI = 231, 218, 221, 222, 225, 226, 227, 228
1. Turn on the Device you want to program. The remote can be programmed by pressing the 3 Digit Brand Code number listed in the code table of this programming guide. If multiple codes are listed, you may have to enter several codes to complete the steps below. (Note: For programming the VCR, a tape must be loaded/inserted first.) If your Brand is not listed, please use the Manual Search menthod or Auto Search method (Section C & D below).
2. Press and hold the SET button for about 3 seconds until the current Device LED lights (TV, VCR, DVD, STB.), then release the SET button.
3. Press the device button you want to program (TV, VCR, DVD, STB.) then the selected Device LED will light on.
4. Enter the 3 Digit Brand Code for the desired Device. For example, enter "2" "1" "8" for AKAI TV. When entering each digit, the Device LED will flash one time. After all 3 digit numbers are entered, the Device LED will turn off. If the code is not valid, the Device LED will flash three times then turn off. Check the code list and repeat from the above step 2.
(*The manual contains a huge list of 3-digit codes for various devices. If you're looking for a specific one, just ask.)
