20 Most Recent
Akai PDP4290 42 in. EDTV-Ready Plasma Television Questions & Answers
Can I hook up cable TV to my Aki a TV model pdp4290
Hi Roger, your Akai PDP4290 TV, is a Monitor, does not bring antenna or cable input
To be able to use it as a Channel Television, you must use a Decoder of some Television service and connect it to one of the inputs that your Akai has
I hope you can solve the problem
Greetings Franco Dosil
Hola Roger, tu televisor Akai PDP4290, es un Monitor, no trae entrada de antena o cable
Para poder usarlo como Televisor de Canales, deberas usar un Decodificador de algun servicio de Television y este conectarlo a alguna de las entradas que posee tu Akai
Espero puedas resolver el problema
Saludos Franco Dosil
While watching it powerd off and has not powerd on since
Good day!!!!That problem is usually cause of faulty capacitors on the power supply board..Just follow this instruction to fix your TV..1. Open the back cover of your TV.2. Look at the power supply board..Its normally connected to the power cord..3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..5. Some of the capacitors not bulged so its better if have a capacitance meter
I need to know what input & output connections
This was the cheapest Akai in its day. No Tuner, No Speakers, must use a surround sound or regular stereo amp for sound.
It also has the standard A/V input also.
Best to use a HD Box and RGB cables for best picture.
Hi, we just hooked up a used (but working) akai tv
Hi
Thanks for using FixYa. Please check the audio with a DVD
player or cable box. Also try using component cables if using a RCA component
cable or vice versa. Check that all of the
cables are plugged into the back of the TV & MUTE button is not pressed. Do
a hard reset by unplugging the power cord for more than 4 hours and power it
again, then go into the on-screen-menu and make sure the sap is off and stereo
in on. If this all didn't resolves the issue then it is a bad speaker/speakers
connection(s). Please do accept the solution if the issue is resolved
else post a comment for further assistance.
Thanks
Rylee
Akai pdp4273m1 has sound but no picture
I also have the akai PDP4273M1 tv with power and no picture and I looked at the power supply board inside and found 1 of the FMG26S chips blown and I am looking into replacing this to see if that does it and if not do a search for SANKEN PSC10165B M and for approx 170.00 you can get a whole new power supply for it and its easy to put in..
Akai PDP4290
yes you it is fixable you are having a micro chip problem or a power supply problem. take it to a tech.to have it repair.
AKAI PDP4273M1 - Unit powers up then shuts down.
I just repaired one for the same trouble. The input to the main processor from the standy switch had shorted to groung. This was probably caused by static inserted when pushing the power button. The processor is not a replaceable part. The part number for the main board is E3761-058010-2. It costs between $140 and $150. I found it on-line at Shopjimmy.com.
Good Luck!
Akai
hi there,
you must told to your hubby to check for the continuity on the main
power supply of the unit, there's a part that need to be Replaced Small
Electros In Main Power Supply.
let me know.
Akai 4290 power board
Yes, I'm sure the board is bad. I had the TV checked out by a local TV repair shop. I also opened the thing up to see if I could do anything with it and it's obvious that this is the board that has bitten the dust. The correct number for the board is AA98-00188A. I made a typo in the first post.
AKAI PDP4290
you need to check the screen voltages inside the unit is a sticker with the voltages on it, if all the voltages are normal, could be the panel is bad, if the voltages are low or nonexistant it could be the L-main,Main or Y-main board
Blank screen
LCD TV/DVD Combo image washout
Instead of reloading the DVD multiple times, when the set is doing this try jaring it with the palm of your hand on a corner near where the DVD goes in. If it clears up when you tap it, maybe you just have a bad connection inside that needs repairing.
