20 Most Recent
Gestetner Copier Questions & Answers
Hi we have just installed
can delete user accounts under system settings. Press the button marked 123(where you get your meter reading). under system settings go to administrator tools and address book managments. can delete user accounts and create new 1's. Or you can trun the user authentcation off. Then no code is needed.
Sender - under system settings go to file transfer. input your smtp and managers account email. When programing user in address book look for add as sender and input the email address. When emailing you can select sender and destination. If the user is not set up as a sender the list will be empty and you would not be able to select a sender. set up a user (email) that any one can use.
Code: SC541
burretha it must be the fusing unit problem thermistor problem
