20 Most Recent
Maylong Android Tablet M-290 Questions & Answers
Can't get to desktop
hard disk is a mechanical device
it has failed and prob need replaced
next time use an ssd and back up regularly
you may be able to recover your data using another pc
and software to recover data check out spotmau .com etc and discover your data
use it too patch the disk on slave issues too access it
then youll get most of the data back
hdd usually crashes on the windows stuff
and the user accounts you can access
win 7 allows you to take control on win xp and other win 7 accounts
if you have the passwords then even encrypted accounts on damaged hdd are available
Why my tablet wont go to the home page
Do you mean it won't go to the "home screen" (past the android guy)? If yes then try to reset it (if a tiny hole on the back exists with "reset" marked, insert a tiny pin and push, so that it restores to factory default settings).
I tried powering up my tablet but it doesn't power up after many tries with many cords and Sears won't take it back. What is wrong?
Hi! I will try to assist you:
1. Make sure the battery is charged enough for the tablet to power on or (if it is not) if you can charge it. An easy way to do thisa is to plug in a charger and see if it indicates that it charges.
If it does not charge, then:
a) The battery is faulty or
b) Something is wrong with the adaptor or the "charge-circuit"
In order for a) and second part of b) to be checked, your tablet needs to be opened!
2. If it charges, then it might be the power button. Try to press it hard enough (try not to break it though) in order to make sure it is not a little bit broken or moved. If still nothing happens then your tablet has to be opened!
3. The screen might be faulty as well.
4. If it is none of the above, then it might be the mainboard. In order to make sure it is not the mainboard, you would need to connect it to an external monitor and see if it works with the external one (I think there is no such option in your case, though)
I assume you wish to experiment-check it by yourself. If you just need a new one, then for instance:
1result for maylong universe
