Typically in the field we test this by starting a normal mode cycle and hold the WPS module in our hand. if after the drain cycle is complete and you feel a small vibration in the module - then the WPS is faulty (common) if no vibration is felt then the control board is failing to supply the WPS with the control voltage to open the solenoid
Try putting vinegar in the rinse dispenser for a few cycles. Monitor the level of vinegar in the dispenser and see if it goes back to normal consumption.
There could be several reasons why this is happening, such as a clogged drain or a malfunctioning drain pump .
Here are some steps you can try to resolve this issue:
Check if the drain hose is clogged or kinked. If so, straighten it out or unclog it.
Check if the drain pump is working properly. If not, you may need to replace it
Check if the filter in your washing machine is clogged with debris. If so, clean it out .
If none of these steps work, it may be best to contact a professional for further assistance.
01, _F, 21
Issue: If the ice has stopped production, please turn the toggle switch off under the electronic touch panel. Advice: We add more information as we learn so if you can't find what you need please ask in the Repair forums.
JustAnswerhttps://www.justanswer.com > Appliance Repair
Mar 5, 2014 - 1. Voltage fluctuations. If the fault code remains after switching the appliance off and on, proceed to Step 2. · 2. Faulty water inlet. Check ...
1 answer · Top answer: Hi, Welcome to JustAnswer. I am a professional appliance repair consultant here to ...
Miele dishwashers, including the G858SCVI Plus model, typically do not have an internal fuse accessible for user replacement. However, there are a few fixes you can try to address the power issue:
Check the power supply: Ensure that the dishwasher is securely plugged into a functioning power outlet. If possible, try plugging another appliance into the same outlet to verify that it is providing power.
Reset the circuit breaker: Locate the circuit breaker in your home's electrical panel that corresponds to the dishwasher. Turn the breaker off, wait for a few minutes, and then turn it back on. This can help reset the electrical connection.
Check the door latch: Make sure the dishwasher door is closing properly and that the door latch is engaged. If the door is not fully closed or the latch is not engaged, the dishwasher may not receive power.
Examine the control panel: Inspect the control panel for any signs of damage or malfunction. Look for loose or disconnected wires or any visible issues. If you notice any problems, it may require professional service or replacement of the control panel.
The F179 fault code on a Miele dishwasher usually indicates an issue with the drainage system. Here are a few steps you can take to troubleshoot and potentially resolve the issue:
Check the Drain Hose: Start by inspecting the drain hose for any kinks, clogs, or blockages. Ensure that the hose is properly connected and not damaged in any way. If you find any issues, clear the blockage or replace the hose if necessary.
Clean the Filters: Remove and clean the filters inside the dishwasher. Accumulated debris in the filters can hinder proper drainage. Rinse the filters under running water to remove any food particles or residue.
Check the Drain Pump: The drain pump is responsible for removing water from the dishwasher during the drain cycle. Make sure the drain pump is free of any obstructions. You can access the drain pump by removing the bottom panel of the dishwasher. If you find any debris or blockage, remove it carefully.
Ensure Proper Installation: Verify that the dishwasher is installed correctly, including the drainage system. Ensure that the drain hose is properly connected to the drain pipe and that there is no obstruction in the plumbing system.
Reset the Dishwasher: Try resetting the dishwasher by turning off the power at the circuit breaker for a few minutes. Then, turn the power back on and run a test cycle to see if the fault code clears.
I had this problem. The manual says to restart the machine and see how it goes. The fault is intermittent. I believe it is due to the non-return ball getting stuck due to swelling of the non-return valve seal. This generates a high pressure which the machine detects as a fault.
Miele video show how to remove and replace the valve.
https://www.youtube.com/watch?v=gqhq8n4GMlA
My non-return valve parts are heat welded together on one side. Other youtube videos show two parts. The heat weld can be broken by bending the two parts apart.
It is clear the ball is "stuck" if you try to push it up from the bottom and clear the black rubber has swelled due to water absorption which is common with black EPDM rubber over time. So I trimmed the "shoulders" off the rubber seal (marked on pics) with scissors to pinch off a little part of the edges where the ball pushes past when water flows. The ball resistance to unseating is much lower the the machine behaves like normal now.
Can't find any pics of the 05750095 part inside to see if Miele redesigned it or changed the seal material. My part 05750093.
(Pics won't upload here for some reason, despite meeting size/format requirements.) See googl photos:
https://photos.app.goo.gl/9nrC31d2QG4hshEQ6
To fix for longer, need to replace the non-return valve seal. The part number on the seal is 0575012. The non-return valve complete part number is listed at the Miele website:
05750095. Non-return valve for dishwashers. Protection against water flowing back into the wash cabinet; for G1xxxG6xxx.
Based on the information you have provided, it seems that your Miele dishwasher is experiencing a drain pump issue, which could be causing the flashing lights and the non-stop running of the pump. Here are a few troubleshooting steps you can try:
Turn off the power to the dishwasher: The first step is to turn off the power to the dishwasher by unplugging it or turning off the circuit breaker. Wait for a few minutes and then turn it back on.
Check the drain hose: Make sure that the drain hose is not clogged or kinked, as this could prevent the water from draining properly. If you find any blockages, remove them and test the dishwasher again.
Clean the filters: Check the dishwasher's filters and make sure they are clean and free of debris. Dirty filters can cause drainage problems.
Check the drain pump: If the drain pump is still running non-stop, it may be faulty and need to be replaced. Before you do this, however, make sure that the pump is not clogged with debris. You can do this by removing the pump and inspecting it for blockages.
Contact Miele's customer service: If the above steps do not resolve the issue, it may be time to contact Miele's customer service or schedule a service visit to diagnose and repair the problem.
It's important to note that attempting to repair appliances yourself can be dangerous, and you should always follow safety procedures and consult with a professional if you're unsure of how to proceed.
