20 Most Recent Biostar P4M80-M4 Motherboard Questions & Answers
You have a very old motherboard here. It only supports the older AGP 8x video cards. Good luck finding one of those anymore that is worth the price, and don't expect anything you find to be new in box. This is probably where your HD video woes start, although the board was never designed for the higher frame rates that HD requires to be viewable.
As far as the processor goes, this board has the Socket 478 for Intel processors. There are no dual-core processors that are supported by this socket. Here is a link to an article that shows what processors are supported by the socket. Be advised, however, that depending upon the BIOS revision on the board, some of these may not work properly, if at all.
Socket 478 Socket mPGA478B
Really, if you want to view HD, it's time for a real upgrade.
Biostar P4M80-M4... | Answered on Aug 24, 2016
Hello Alienware,
Could be a few things.... such as the micro-fuses that have gone on the MB....
But what I dont understand is this:...."Then I disconnect the 4-pin cable that goes from the Power Supply to the motherboard near the CPU and the pc turns on fine"
How????
You have just disconnected the cable from the PSU to the motherboard....it CANT turn on! LOL.
Do you mean that the lights turn on?
Or you hear the HD spin up (if you left it connected to the MB that is)?
Please advise so I can help you more.
Biostar P4M80-M4... | Answered on Nov 22, 2014
still on the cpu? if so becareful let the lockdown leaver up then take out cpu
Biostar P4M80-M4... | Answered on May 14, 2014
Sounds like the PSU. Can you borrow one to test?
Biostar P4M80-M4... | Answered on Nov 11, 2013
Try here: Drivers
Biostar P4M80-M4... | Answered on Jan 28, 2012
Disconnect the hard disk and reboot - wait for its absence to be detected then shut down the pc , reboot and go into the BIOS and make sure the AGP is enabled. Shut down the pc again, insert the new video card, connect the monitor to it then start the pc and go into the BIOS - now you should be able to disable the onboard one.
Connect the hard disk and you're good to go.
Biostar P4M80-M4... | Answered on Sep 05, 2011
?¸??¹??¸­?¸??¸?¸²?¸£?¸£?¸«?¸±?¸??¹?¸¥?¸°?¸§?¸´?¸??¸µ?¸?¸²?¸£?¹?¸?¹??¹??¸??¸??¸£?¸±?¸š ?¸??¸­?¸š?¸??¸¸?¸??¸??¸£?¸±?¸š
Biostar P4M80-M4... | Answered on Jul 10, 2011
You have not mention your Operating System(OS) on your PC System.
To get USB 2.0 support for VIA Chipset Mainboard
1. For Win 98 OS, you have to install "VIA chipset USB 2.0 driver"
2. For WinXP OS you must install, at least Service Pack 1, (recommended you install the lastest Service Pack 3) to to get USB 2.0 support.
3. Install the VIA Chipset drivers for your Mainboard ie "VIA Hyperion 4-in-1 driver v5.12A".
Hope it helps.
Biostar P4M80-M4... | Answered on Jun 02, 2011
That is the smell of blown capacitors either from the motherboard or the power supply.
Biostar P4M80-M4... | Answered on Mar 10, 2011
Press F2 at startup
Biostar P4M80-M4... | Answered on Mar 08, 2011
The chipset i fried if you don't get any beeps at all. You'll need a new motherboard.
Biostar P4M80-M4... | Answered on Feb 15, 2011
http://www.biostar.com.tw/app/en/mb/content.php?S_ID=246
download here
i hope this helpful
thank you for using fixya
Biostar P4M80-M4... | Answered on Feb 05, 2011
This is an older board. The VIA chipset pre-dates dual channel memory support. If your board is working fine, this should not be a concern.
Biostar P4M80-M4... | Answered on Jan 12, 2011
For problem #1 you need to be sure you have the proper codec installed for playing the movie..you can obtain codecs from the internet...also...do you know how much memory is installed on the video card..you may need more...the more video ram you have..the better the picture and the way it is buffered..as for problem #2, you can go to the manufacturer's website for the make of soundcard you have...or you can check for it at microsoft.com....as far as an agp card...go to the biostar website to see what they recommend...you can download the user manual here for the motherboard also..which can be very helpful in setting up the m-board
Biostar P4M80-M4... | Answered on Jan 07, 2011
Hi, you can download the sound driver for your Biostar motherboard here:
http://www.biostar-usa.com/mbdownloads.asp?model=P4M80-M4
Just look under "Audio" and click the right one for your operating system.
Thanks for using FixYa!
Biostar P4M80-M4... | Answered on Jan 06, 2011
Here is the specs of the memory that you can use for this motherboard.
2 x 184-pin DDR SDRAM
PC3200 (DDR400) DDR SDRAM
Maximum 2GB
Biostar P4M80-M4... | Answered on Jan 03, 2011
Biostar P4M80-M4 Motherboard Logo
84 questions posted
Top Biostar Computers & Internet Experts
Jayburt
Ekse
Thomas F. Schneider
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Biostar Computers & Internet
Most Popular Question
i84gv m4 audio driver
  • Computers & Internet
