20 Most Recent
Jetway 939GT4-SLI-G Motherboard Questions & Answers
What is JBAT on Motherboard
Clear CMOS (JBAT)
if the computer will not boot move the jumper the 3 pins to the other side.
8/29/2011 4:56:07 AM •
Jetway...
Answered
on Aug 29, 2011
Jetway motherboard 939 GT4-SLI-G will
If you are running a 32 bit version of windows it will only see up to 3.5gig of ram in your system no matter how much ram you put in there.
This is down to 32 bit windows only being able to address a maximum of 3.5 gig of ram.
Windows 64bit can address a far larger amount of ram and is why you will see all windows computers running 4gig or more of ram having Windows 64bit installed.
As you have said your computer is running Windows 7 32bit the only way you will get your computer to see the whole 4gig of ram you have installed is to upgrade to Windows 7 64bit.
Hope this answers your question and helps you out.
1/18/2011 10:40:39 PM •
Jetway...
Answered
on Jan 18, 2011
In boot protection and missing password
Have you reset the CMOS by jumping the pins? Or just remove the battery
for about 30 seconds. This should remove all passwords and bring your
BIOS back to factory default. Its much easier having the manual.
Hope this helps.
11/8/2009 7:49:41 PM •
Jetway...
Answered
on Nov 08, 2009
Problem with mobo upgrade ... From Intel CPU to AMD CPU
hi dale, itsnot a good thing when you see the blue screen of death, cause recent changes hardware normaly maybeif you have changed from intel to amd using mobo and all parts are amd now , maybe if you reinstalled your operating system the new hardware that is installed will accept you software cheers steve good luck
7/18/2009 6:48:53 AM •
Jetway...
Answered
on Jul 18, 2009
Adding 2 gigs memory
try to install windows xP!! when the screen turns blue!! just press f7 until the setup is finnish!!
7/16/2009 4:05:54 AM •
Jetway...
Answered
on Jul 16, 2009
Tops blown off
This isn't going to solve your issue, but my opinion is that if even if your computer is still running it is still an issue that they should look at especially if the board is still under warranty. I wouldn't say a thing about the computer still being able to run, especially if they will warranty it.
I have seen capacitors burn up, but not the tops blowing off. Even though the board is still working you may have a feature of some sort out, such as you onboard video or something. I almost bet that something is still wrong, and it would be a matter of time before you have more issues.
10/4/2008 8:44:57 PM •
Jetway...
Answered
on Oct 04, 2008
Will not boot into Bios
hmmm... why dont you try to reinstall your OS...maybe there's something wrong with that..^ ^
3/10/2008 6:42:53 AM •
Jetway...
Answered
on Mar 10, 2008
Won't boot without a windows disk...
Just taking a guess here. Did you do a fresh install of winXP? This type of problem is usually caused because the boot.ini is out of order OR your BIOS settings are not correct. Get into windows however you have to. Once in windows you'll find the boot.ini on the root of C:\ Please copy this file to a floppy disk just in case you make a boo-boo.
You need to check this file. Double left click the file & it will open in notepade. There are five lines and they must read like below, do not make a single line turn into 6 lines.
It should look just like this:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
The only differance between you & me might be the "name",
I use Windows XP Professional, yours might read Windows XP Home Edition.
Change what you need "only" and save the file. Double check. Than remove the CD from your PC and shut down. Wait a minute and start it up.
3/4/2008 7:00:04 PM •
Jetway...
Answered
on Mar 04, 2008
Help
Ok Sorry about the chat connection. I lost my internet connection
Please enable me to chat again
I can help you with this
2/10/2008 10:50:20 PM •
Jetway...
Answered
on Feb 10, 2008
DRAM Beep
Try to clean the bronze circuit of your VGA card and insert it again, if its the same Your video card is broken, you need to replace..
1 Long beeps means theres an error on your vcard / or theres a problem on it..
3 short beep means thats your RAM have an error or a problem on it..
Once the if the mbord doesnt gives any sign or a beep and seems to be blackout there could be a short circuit on your mbord to the parts with a connection to it...
2/2/2008 3:56:18 PM •
Jetway...
Answered
on Feb 02, 2008
Driver
Welcome To Jetway Home Page..
this company use nForece520LE(MCP65V)chipset
motherboard and can not stall RAID disk
driver in CD,for ... Example to
JETWAY 939GT4-
SLI-
G mainboard.
You will find the driver on this link, Read follow instructions.
Good Luck, Please dont for get to Vote/Thank You.
12/26/2007 9:01:23 PM •
Jetway...
Answered
on Dec 26, 2007
Broken PC
test all parts and come back to me
mbern
8/23/2007 3:02:47 AM •
Jetway...
Answered
on Aug 23, 2007
