20 Most Recent
Akai PDP4295ED 42 in. EDTV-Ready Plasma Television Questions & Answers
Need to hit the cable button without the remote
Good morning On most newer televisions there are touch buttons down in the right hand corner on the front of the appliance. There are mostly the same functions as on the remote.Go to the input and you will get the same picture up as with the remote. Choose cable then OK.The buttons are very sensitive so you may have to make a few attempts before you get there, but you will.enjoy your coffeeKolbrun
My akai model no:PDP4295ED has a black line down
How much experience do you have with electronics repair? I have repaired mine from this problem but the solution would be difficult to describe here. If you a patient I may be able to help but I'm afraid to write this here for fear of injury to somebody.
Color problems
I have the same problem... today I got a digital satelite tech come out and hooked a HD digital reciever to the tv and now I have the greenish/yellowish/blue tint hhhmmmmmmm?
Need Codes for Akai television using Stang F-2100 universal remote.
It is 2023, no one uses Universal Remotes these days!
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Codes are to the television maker, they don't change depending on the make of remote used. But as I said, no one buys universals, you buy a copy remote made for the make model you have.
Akai TV universal remote control codes (3, 4 and 5 digit)
eliztech.com
https://www.eliztech.com > remotes > codelists > akai-t...
Universal remote codes for Akai TV sets - 3 digit, 4 digit and 5 digit codes. ... Mixed Akai TV codes from nine brands of universal remote controls.
3, 4, & 5 Digit Akai TV Remote Codes with Programming Guide
smarttvremoteapp.com
https://smarttvremoteapp.com > akai-tv-remote-codes
Akai TV Remote Codes for DirecTV ; 11385, 11692, 11935, 12232 ; 10765, 10812, 10030, 10098 ; 10672, 11676, 11689, 11690.
Universal Remote Codes for... ·
Akai TV Remote Codes for Dish
I have a pdp4298ed1 akai TV with a digital antenna screwed into the ant in. How do I scan for digital channel's?
To scan for digital channels on your Akai PDP4298ED1 TV, you can follow these steps:
- Press the "Menu" button on your TV remote.
- Use the arrow buttons to select the "Setup" menu and press "OK".
- Use the arrow buttons to select the "Installation" option and press "OK".
- Select "Automatic Search" or "Auto Scan" and press "OK". The TV will begin scanning for digital channels.
- Once the scan is complete, the TV should display a list of channels that it has found. You can then use the arrow buttons to select a channel and press "OK" to tune to it.
If the auto scan feature does not work, you may need to try a manual scan instead. To do this, follow the same steps as above but instead of selecting "Automatic Search", choose "Manual Search" and enter the frequency of the channel you want to tune to. You can find the frequency information for your local channels by doing a quick online search or checking with your local TV provider.
