20 Most Recent
Akai CFTD2085V 20" TV/VCR/DVD Questions & Answers
Akai cftd 2088 TV comes on . goes off after about
You're might correct that your unit goes to overheating which produce an out of regulation on the supply. This is mostly caused of the ff:
1. Leaky filter capacitor on the regulator section - this will affect the regulation of supply which causes subsequent shutdown
2. Leaky volt regulator IC - it will overheat fast.
3. Leaky filter capacitor on the system supply.
Diagnosing the faulty parts is not diy so i've advice you to look for a qualified tech to do the job.
Have a nice day!
Thanks for using fixya.
DVD player not working, only used a few times AKAI
Unfortunately they are a real bare to fix. Unless its a jammed disc it is probably a defective transport. If it is under warranty have it repaired otherwise get an external DVD player.
Sorry I don't know of any easy fix for the integrated units.
Cheers
No picture
your tv needs to be swithed frm av to tv from its remote.if you dont have a remote buy a universal that will work with this brand,read universal code list before buying!!!
I have a AKAI CFTD
If connected to cable or satellite your tv will work after digital conversion occurs. If using an antenna, look up a local TV station to see if they're already broadcasting in digital. Most are. Enter that DIGITAL channel # using your remote. If you get a picture, you don't need a converter box.
Need Codes for Akai television using Stang F-2100 universal remote.
It is 2023, no one uses Universal Remotes these days!
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Codes are to the television maker, they don't change depending on the make of remote used. But as I said, no one buys universals, you buy a copy remote made for the make model you have.
Akai TV universal remote control codes (3, 4 and 5 digit)
eliztech.com
https://www.eliztech.com > remotes > codelists > akai-t...
Universal remote codes for Akai TV sets - 3 digit, 4 digit and 5 digit codes. ... Mixed Akai TV codes from nine brands of universal remote controls.
3, 4, & 5 Digit Akai TV Remote Codes with Programming Guide
smarttvremoteapp.com
https://smarttvremoteapp.com > akai-tv-remote-codes
Akai TV Remote Codes for DirecTV ; 11385, 11692, 11935, 12232 ; 10765, 10812, 10030, 10098 ; 10672, 11676, 11689, 11690.
Universal Remote Codes for... ·
Akai TV Remote Codes for Dish
I have a pdp4298ed1 akai TV with a digital antenna screwed into the ant in. How do I scan for digital channel's?
To scan for digital channels on your Akai PDP4298ED1 TV, you can follow these steps:
- Press the "Menu" button on your TV remote.
- Use the arrow buttons to select the "Setup" menu and press "OK".
- Use the arrow buttons to select the "Installation" option and press "OK".
- Select "Automatic Search" or "Auto Scan" and press "OK". The TV will begin scanning for digital channels.
- Once the scan is complete, the TV should display a list of channels that it has found. You can then use the arrow buttons to select a channel and press "OK" to tune to it.
If the auto scan feature does not work, you may need to try a manual scan instead. To do this, follow the same steps as above but instead of selecting "Automatic Search", choose "Manual Search" and enter the frequency of the channel you want to tune to. You can find the frequency information for your local channels by doing a quick online search or checking with your local TV provider.
