20 Most Recent
Samsung Galaxy Tab 2 7" 8GB Android Tablet with Wi-Fi 802.11 b/g/n, USB 2.0, Titanium Silver Questions & Answers
To many patten attempts
- With the Samsung Galaxy TAB turned off, press and hold the VOLUME Down button, and then briefly press the POWER button.
Note: If you see "Downloading" on the screen with an Android shoveling you pressed the wrong Volume key. Remove and reinsert the battery and try again.
It should hard reset any of these tablets:
Reset GT-P6210 Galaxy Tab Plus 7.0 WIFI
Reset GT-P6200 Galaxy Tab Plus 7.0 WIFI + 3G
Reset GT-P6810 Galaxy Tab 7.7 WIFI
Reset GT-P6800 Galaxy Tab 7.7 WIFI + 3G
Reset GT-P7310 Galaxy Tab 8.9 WIFI
Reset GT-P7300 Galaxy Tab 8.9 WIFI + 3G
Reset GT-P7510 Galaxy Tab 10.1 WIFI
Reset GT-P7500 Galaxy Tab 10.1 WIFI + 3G
To many pattern attempts
the only way to not get this code is to use the correct unlock pattern within 3 attempts. else you must wait about 15 minutes I think is about the time, a minimum wait time of 30 seconds and depending on how many times you've tried to unsuccesfully unlock it, up to 15 minutes
Tablet problems with touch of the screen
let's start with the basics first in order to solve your tablet issue. Once we go that, we can move forward as necessary.
I would recommend performing an antivirus scan on your device. You can search for "avast" or "malwarbytes" in your app store to get started.
If that doesn't work, then you can perform a factory reset as described by Samsung here:
https://www.samsung.com/us/support/answer/ANS00062842/ . You'll be advised to back up your files before performing the factory reset.
Please let me know if this helped you or not.
