20 Most Recent
Motorola Mobility Universal Wireless Bluetooth HS850 Headset Questions & Answers
I want to pair my 850 bluetooth with a new phone.
Hi, you don't need to unpair the old device, Just pair the new device,it does not have anything to do with the old one.
Step 1: Set the headset to be discoverable
1. Turn off the headset.
2. Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
1. On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
2. On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000.
See the instructions that came with your other Bluetooth-enabled device for more information about pairing it with Bluetooth devices.
Hope it helps.
Feel free to pass your comment.
Thanks for using fixya...
1/9/2011 4:52:16 PM •
Motorola...
Answered
on Jan 09, 2011
How to reset Motorolas HS850 bluetooth headset
How to place a Motorola HS 850 bluetooth headset into paring mode:
- Close the boom to turn the unit off.
- Hold down the call button until the blue light comes on.
- While holding down the call button, swing the boom open.
You'll also need to enter the Lotus' bluetooth utility and have it search for bluetooth devices. If you set a password on the headset, you'll need to enter that password. If you didn't set a password and it asks for one, then the default is usually 0000 or 1234.
11/2/2009 5:32:25 PM •
Motorola...
Answered
on Nov 02, 2009
Having problems pairing
How to pair a Motorola HS850 bluetooth headset
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
9/22/2009 4:09:54 PM •
Motorola...
Answered
on Sep 22, 2009
Bluetooth
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HS850 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
1/31/2009 9:49:04 AM •
Motorola...
Answered
on Jan 31, 2009
Bluetooth head set
Tips:
1/22/2009 12:04:39 PM •
Motorola...
Answered
on Jan 22, 2009
Motorola bluetooth headset HS850
There are several possible reasons for this problem.
Try the following steps:
- Shut off the headset.
- Shut off bluetooth on your mobile phone and restart it.
- Now bring your headset in pairing mode. How to do this should be explained in the manual.
- go to something like "add new bluetooth device" on your phone. Something like that should be in the bluetooth menu.
- the phone should find the headset now. Pair the devices using pincode 0000. That's normally the code for headsets.
you can use the headset now.
If one of the steps gives problems, just ask. Then I will try and give some more specific help.
Please give some reaction also if this was helpful...
Ruud
1/4/2009 10:45:39 PM •
Motorola...
Answered
on Jan 04, 2009
Bluetooth hs850
On the following link you will find a very useful pairing guide that will take you through the setup.
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=38b5f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=fd13e7af976c9010VgnVCM1000008206b00aRCRD
Please update the question & let us know if the information given was useful to you - Good Luck!
10/12/2008 12:11:08 PM •
Motorola...
Answered
on Oct 12, 2008
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
