20 Most Recent
Candy CPCA250K Bottom Freezer Refrigerator Questions & Answers
Temperature adjustment
Generally the freezer temp is the REAL temp of the unit. Fans, dampers and manual control levers let some of that cold freezer air into the refer compartment to cool it. Check your owners manual for damper operations if you have one. If you have a refer temp control all that does is control a damper to let the cold freezer air into the compartment. Also make sure you don't block off any of those vents in the refer or freezer compartment or bad air circulation can occur.
Water at the bottom of the freezer door
The seals around a fridge or freezer door are of a memory type rubber compound.
Therefore the way to repair / rejuvinate a seal that has become squashed over time is this.
Obtain a hairdryer and on a medium heat warm up the seal, you will see it plump in front of your very eyes! work your way around gently untill the whole seal has plumped up.
When done, allow to cool for a few minutes (if your hairdryer supports cold blowing then do that)!
Then close the door, you will feel the difference.
2 things to remember, firstly water and electric don't mix! Secondly ensure that you are only warminmg up the seal and not burning it, ensure you start from a distance.
Hope this helps you, Chris
Candy CPCA240FFK top fridge door seal required?
They need to be for the model itself as opposed to by sizeCandy CPCA240FFK Seals - Fridges & Freezers - eSpareshttps://www.espares.co.uk > ... > Candy > SealsFridge/Freezer Door Seal. 3.6. Genuine spare part for select models of Candy, Hoover and Kelvinator fridge and freezers More information. In Stock.Candy Door Seal for CPCA240FFK - ES929589 - eSpares
https://www.espares.co.uk > product > door-sealWill this part fit my Appliance? Yes. This part is compatible with Candy CPCA240FFK Fridges & Freezers. Not what you're looking for?Candy CPCA240FFK Fridge & Freezer Door Seals - Ransom Spareshttps://www.ransomspares.co.uk > ... > CPCA240FFKBuy Candy CPCA240FFK Fridge & Freezer Door Seals from the authorised stockist. Low prices with our Price Match Promise & next day delivery - Ransom Spares.Candy CPCA240FFK Fridge & Freezer Spares & Parts
https://www.ransomspares.co.uk > ... > CandyBuy genuine replacement Candy Fridge & Freezer CPCA240FFK spares from an authorised supplier. Price match promise and next day delivery.
9/29/2021 2:46:33 PM •
Candy...
Answered
on Sep 29, 2021
