20 Most Recent
Equator EZ 3710 Front Load Washer / Dryer Questions & Answers
I'have a equator washer n dryer///ez3710v
if you are still waiting for a solution on this here it is:
Each and every wire in this unit are labelled and so if you can see the labels on the four wires they would be labelled as FD, FDX, FE & FEX, FD & FDX should be connected to the two black dots and FE & FEX should be connected to the two red dots.
Washer/Dryer not drying
is your dryer a conderser type
does it have a tank that you have to empty at the end of cycles
if it does the filter that condensers the water from drying cycle
if that is blocked it will not work
How do I reset my Equator Super Combo washer Dryer EZ4000?
To reset your Equator Super Combo washer dryer EZ4000, you can try the following steps:
1. Unplug the unit from the power source and wait for a few minutes.
2. Plug the unit back in.
3. Press and hold the "Start/Pause" button for about 5 seconds to reset the machine.
This should reset the washer dryer and clear any error codes that may be causing the issue.
Regarding the door interlock switch, you can try finding a replacement locally by contacting appliance repair shops or stores that specialize in appliance parts. You can also search online for retailers or websites that sell spare parts for Equator appliances. Provide them with the make and model of your washer dryer to ensure you get the correct part.
If the above steps do not resolve the issue with your washer dryer, it may be best to contact Equator Appliances directly or consult a professional appliance repair technician for further assistance. They will be able to provide you with more specific guidance and help you troubleshoot the problem effectively.
