20 Most Recent Samsung Precedent Smartphone Questions & Answers
Sadly fixya can ot help with this problem. try SAMSUNG or a phone repair facility
Samsung... | Answered on Jun 11, 2017
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Samsung... | Answered on Mar 26, 2017
Default code should be 0000, 1111, 12345.
If none of those work and you are unable to use the device or would like to wipe(erase) the device, look below.
If you are trying to erase everything from the phone: Pull out the battery or power off the phone, Hold the Volume up and camera button, while holding both buttons, press and hold the power button until boot., after the nudge or as soon as the Samsung logo shows, let go of the power button(keep holding the other 2(volume up and camera).
When a little android with something on it's chest, let go of the buttons, wait until the menu shows up and use the volume buttons to move down to wipe userdata, press the power button to select the option highlighted.
Samsung... | Answered on Apr 15, 2015
I recommend you get someone to check the charge port, if you feel comfortable opening the phone, just look and make sure it's not damaged or corroded.
Samsung... | Answered on Jul 03, 2014
leads can be purchased
Samsung... | Answered on Sep 21, 2013
Master Code 1122
Samsung... | Answered on Dec 29, 2012
make sure your phone is configured to its network settings correctly by going to settings, network. and make sure you have a signal on your phone. if you have turned on your flight mode, turn it off..
What is the extension of the video? .mov .mp4 ? Download VLC media player, it can play almost every video format. http://download.cnet.com/VLC-Media-Player/3000-13632_4-10267151.html?tag=main;pop
Samsung... | Answered on Oct 30, 2012
Recovery sequence here: http://answers.yahoo.com/question/index?qid=20111002094500AAYN4B5
Just be aware, this may restore your phone to factory settings (that is, your data may be lost at this point).
Samsung... | Answered on Oct 23, 2012
wrong forum posted (answer are better and faster using the right forum.
post to TV not PC.
or read the manual at Samsung.com
the remove may have weak batteries.
Samsung... | Answered 3 days ago
Android is not compatible with your model....You may want to refer below mentioned link for more information
http://www.topandroidphones.com/android-phone-list/
Samsung... | Answered on Jan 13, 2020
How to fix The Specific Code Is 0xc0000185 errors? There are several methods of fixing The Specific Code Is 0xc0000185 errors. You may need to try more than one method before you're successful.
Download the (The Specific Error Code Is 0xc0000185) repair tool. avg-linkscanner-verisign-safe.jpg Install the program and click on the Scan button. Fix any errors it finds once the scan is complete. Restart your computer.
• Manually edit your Windows registry. Start the registry dditor by clicking the Start button, typing regedit in the Search box, and pressing Enter. Open the HKEY_LOCAL_MACHINE folder ==> "Software" folder ==> "Microsoft" folder==> "Windows" folder ==> "Currentversion" folder. Click on the Run folder ==> Click on the The Specific Error Code Is 0xc0000185 file. Delete the file by pressing Delete The Specific Error Code Is 0xc0000185 key. You can then reinstall the file on your PC
• Update the drivers for the device. It's possible that installing the latest drivers for the device could correct the error. If this works, it means that the existing drivers you reinstalled in the step above may well have been damaged.
• You can also download the Windows The Specific Error Code Is 0xc0000185 recovery utility which has proven successful at fixing this error..
Samsung... | Answered on Jan 09, 2020
You can't. ( well not easily anyway )
What If app is designed to run on Apple mobile operating system and the other version is designed for Android mobile operating System or for Tablets.
In theory you would need a Android emulator program to trick Google play store into thinking your p.c is an android device .
(have not tried this myself just logical reasoning)
http://techapple.net/2014/12/top-7-free-android-emulators-windows-788-110-pccomputer-run-android-appsgames-windows-78-110/
then you would need to download the google play store application to your pc and install it into the p.c under the pretense cover of the emulator .
https://www.youtube.com/watch?v=DSRFEIgHHvQ
Blue stacks mentioned in the above video is an android emulator
Or take an apple approach
http://techraze.com/best-ios-iphone-ipad-emulator-for-pc-download-windows-mac
Samsung... | Answered on Jan 06, 2020
http://www.samsung.com/us/support/owners/product/UN32EH5000FXZA
Samsung... | Answered on Dec 27, 2019
Samsung Precedent Smartphone Logo
34 questions posted
Top Samsung Computers & Internet Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
unlock samsung sch m828c
  • Computers & Internet
