20 Most Recent
Earthquake Sound XTREME 900W.5 Car Audio Amplifier Questions & Answers
Wiring problem
If you have an aftermarket stereo, the hook up is fairly simple. On your amp there should be a minimum of 5 terminals and an audio input. one is for remote which is connected to the blue wire on your stereo. Second is your ground which is your negative connection. it should be connected to the body of the car close to the frame. Third is your hotwire which is the positive lead, it should go straight to your battery. The fourth and fifth are speaker wires, you may have 2 or more of these that have + and - signs above or below them. When wiring the speakers make sure to match the positive and negative connections on the speakers. If your rewiring all of the door speakers to your new amp then the colors that you see once you have them out are the colors you route to the appropriate locations on your amp. If this is for a sub then you just the connect th positive terminal on the sub which is red to the + on the amp and the black terminal on the sub the the - location on the amp.
Lastley there should be an audio input that runs from your stereo to your amplifier. This wire should be ran as far away from the positive wire as possible to avoid engine noise coming through your speakers.
Sound from speakers muffle mid song
Assuming you've already checked all your wiring, it sounds like a problem in the amp circuitry. Would you say it happens when the amp heats up? I'm guessing an input opamp circuit is messing up when the amp gets hot. If you are electronically inclined you could open it up and look for a poor solder joint. Other than that you will likely have to get it professionally serviced.
Directed audio 800a amp the protection light keeps blinking
1. Check your grounds. (including grounds for your stereo)
2. Check to make sure the power cable you connected to your car battery is properly connected, and not coming into contact with anything metal.
3. Make sure you are using proper fuses.
4. Check your connection from your stereo to your amp, and your amp to your subs.
Fan on Amp turns off with everything off.
yes , it is normal for the fan on the amp to turn on when the internal tempature reaches 110 degrees the amplifier is not an intellegent device, all it knows is the temp threshold has been reached and its themostat will close the relay and try to exhaust the heat from the amplifier....I have this same amp, and I live in florida...thank goodness it is a very minimal draw,,,btw if it was a 100 outside it was well above 100 inside your car and even hotter inside the amp ,,the heatsink will conduct heat inside the unit when the unit is off....so the unit is behaving normally...Congratulations for buying a high quality piece of electronics
How do you wire 2
What are you wiring too? What kind of amplifier?
What impedance are the voice coils on each speaker?
If you send me the above info I can better assist you with this dilema.
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
