20 Most Recent
Eclipse CD5405 Questions & Answers
Help displayed after power loss!
5341R
Ser:
Hello
What is the fault with your Ecilipse CD5405? You haven't described anything about it here, except a mere number. What should I understand from that? Please give me details of fault that you feel with your device. Give me as far as details as you can. OK.
My CD5405 has gone into
Canceling or unlocking the
security feature is done by a KEY CD. When you got the player you might have registered a KEY CD with your player.
Please insert that key CD and OK will appear in display and CD will start
playing .This will unlock the player.
If you don’t have this CD please
contact you eclipse dealer and they will rest the full system and will unlock
it.
Thank You
Car stereo lock up
Hi basic101
There is a security cd that comes with the unit originally. You use that to reset the code. without it, is difficult to fix here in this forum. .
There is also antoher way, if you had the unit installed,try playing the first Cd you ever played on the system. That apparant;y is a method for unlocking them also.
Other than that, you may need to get the serial number off the unit and get in touch with your local Eclipse Authorised repair guy.
I am more than happy to answer
any other questions you may have about it, just give me a hoy :) If you
are still unsure, or have problems, then before you give a rating for this advice, please
get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you
as sound, a FixYa rating is a great reward for my efforts to help
you. Cheers.
regards
robotek
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Setting the clock on Eclipse cd5405 deck
Push the function button once. turn the right knob (SEL) untill CLOCK ADJ shows on the screen. push SEL in one time to lock in CLOCK ADJ and the hours will blink. Turn the SEL knob to set the hours. push SEL again to get to the min. Turn SEL again to set min.
Eclipse AVN-310C. How to connect to Bluetooth while your screen is invisible.
I apologize for not being able to see your exact device, but I can provide a general set of steps that might help you navigate to Bluetooth settings without seeing the screen. Keep in mind that button layouts may vary, so these steps are not guaranteed to work but may still be helpful.
Assuming your Eclipse AVN 3310c is on:
1. Press the "MENU" button (usually located near the top of the device or on a panel to the left of the screen) to bring up the main menu.
2. Press the right or down arrow button (usually located near the Menu button) a few times to navigate to the Settings menu. You may need to experiment with the number of presses to reach the correct menu.
3. Press the "ENTER" button (usually located in the center of directional buttons) to select the Settings menu.
4. Press the down arrow button several more times to navigate to the Bluetooth settings. Again, you may need to experiment with the number of presses to reach the correct menu item.
5. Press the "ENTER" button again to access the Bluetooth settings.
6. Within the Bluetooth settings, u should be able to click it on.
Since you cannot see the screen, you will likely have to go through these steps multiple times, experimenting with the number of presses and order of options in each menu. Enlist someone who is familiar with your specific model or use earphones to listen to feedback from the device in case there is some audible indication of menu navigation. Good luck!
How do I set the time on the eclipse AVN RB7
To set the time on an Eclipse AVN RB7, you will need to access the menu system on the device. Here are the steps you can follow to set the time:
- Press the "Menu" button on the device to enter the menu system.
- Use the navigation buttons to select "System" and then press the "Enter" button.
- Select "Clock" and then press the "Enter" button.
- Use the navigation buttons to set the correct hour and minute, and then press the "Enter" button to confirm the time.
- Press the "Menu" button to exit the menu system.
If you are having trouble accessing the menu system or setting the time on the Eclipse AVN RB7, you may want to consult the device's user manual or contact Eclipse for further assistance.
