20 Most Recent
Western Digital Caviar WD800BB 80 GB Hard Drive Questions & Answers
Driver
your OS should apply a generic driver for it. there is no specific spot to download a driver for a HDD
Hi.How to install a HD
Hi,go to bios setting first boot would be the hard disk and the second booth would be the optical drive.thanks
Western digital wd800bb-55jkco missing 4Gb even
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
I have a Western Digital
You can refer to this:
If you need further help, let me know.
Good luck.
Thanks for using
FixYa.
Please:jumper settings
Here you are:
Good luck.
(A comment to the previous solutions..)
My external hard drive WD800
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external ,
go to Start-Control Panel-Administrative Tools-Computer Management-Disk
Management , and see if your external drive is listed here with your
local drives. If it is listed , right click on the drive and change the
drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your
computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your
computer case or another external case.If the drive works , the problem
is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
- The USB cable between the drive and the computer may be damaged.
- The circuit board which connects your drive to the interface of the external may be blown.
- The power supply (if applicable) may have a blown transformer.
The
latter is the easiest to diagnose , does your external light up at all
when you plug in the power? If not , then this is probably your problem.
On the bottom of the adapter is a label which you will be able to use
to have a new adapter made at your local electronics shop and this will
cost about $30 max. They will also be able to test the adapter with a
clamp meter to see if this is really the problem and this should be
free.
The second component you want to test is the USB cable. If
you have a printer , swop out the cables and see if your printer
functions normally. Most externals use the same connector so you should
be able to test it in this manner. If the cable works go on to the last
step. If the cable is defective , replace it with a new one which you
can find for about $10 at most electronics and chain stores.
The
last component to test is the circuit board. This is a bit of a grey
zone as you probably won't be able to spot the blown component unless it
failed really badly. With the casing already opened , locate the
external's circuit board and check to see if you have any blackened
components or fluids leaking from some components. If all the other
components of the external worked perfectly , then this is the faulty
part. It is not really economical to replace the circuit as most of the
time it is out of production by the time you need to replace it and it
still costs a lot even if it is available so if your drive is working
perfectly when connected via sata or IDE on your computer , the best is
to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Wd hdd 80 gb sata clicking problem not detect
The moveable read/write "head" inside the disk-drive (like the needle and arm on a vinyl record player) is making the "clicking".
It's a sign that the disk-drive is "dead".
Search online for a professional "data recovery service" -- for a large fee, they can repair the disk-drive, just long enough to copy your files onto a new disk-drive.
I moved my desktop hard drive WD 8000BB to an
Does it power up when you plug it? If not, it could be a problem with the power from the USB port. If it does, see if it shows up in the Disk Management.
More ideas: http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
The hdd does spin but is not detected
it is phyisically damage and will not work it is bettre just replace the hard dirve.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
