20 Most Recent
JBL On Tour Computer Speakers Questions & Answers
How Dismantle jbl on tour
First you need to remove the sliding door. You can do this by opening it and lifitng one side with a screwdriver like on one of the pictures.
After that you can remove the battery cap and batteries.
Than you will need to remove the JBL logo. This is quite tricky. because it is glued. After that you can remove all the torx screws and open the device.
http://imgur.com/a/CzyatI damaged mine because I didn't have proper tools. Fixed the speaker though.
Hi I want to open
Its pretty late for your post....but today i repaired my jbl on tour...there are 7 screws to be removed. 2 on thre front upper side, remove the battery cover an you find the first two. then remove the jbl sign, theres another under it. its very hard to remove, i had to destroy my jbl sign. now you have to clip out the cover when you have slided it back, under the back side who was covered, are the last 4 screws. now the nasty part is coming: you cant open it, cause its glued all around. put at first a knife into the slot betwen the upper cover & the under cover, move it around the jbl on tour, but watch out that you damage no electronic parts, or cut off the battery cabel (as i did ;) ) and now you can open the device. my jbl looks really bad after, but it works fine (had issues with the current cable)
Just not working
Suggest that the internal amp is faulty, best to take to repair shop.
How to open jbl on stage 200id?
To open the JBL On Stage 200iD, you need to follow these steps:
Remove the power adapter from the back of the device.
Turn the device over so that the bottom is facing up.
Locate the six rubber pads on the bottom of the device and remove them using a plastic opening tool.
Remove the six 1cm T-10 torx screws found under the rubber pads using a T-10 Torx screwdriver.
Open the device along its seam.
For more information, please refer to the JBL ON STAGE 200ID USER MANUAL.
https://www.manualslib.com/manual/788652/Jbl-On-Stage-200id.html
10/27/2023 9:59:32 PM •
JBL Audio...
Answered
on Oct 27, 2023
Problem with your JBL BoomBox2 speaker (or similiar) ?
Just found this out, after crazy searching & brainstorming.
So if your speaker suddenly goes silent or sound comes and goes, you can check this out:
At least the JBL BoomBox seems to have this integrated in its architecture so there's nothing we can do about it, complain to JBL : )
But to the problem: if the SOURCE of music/sound is too low, then the speaker may go into a "sleep mode" - silent. So ensure always your SOURCE of sound, connected to the speaker, has volume at least 80% to avoid this problem.
Hope this helps & no one needs to ditch and buy a new one ! : )
How do I fix a BLINKING light on the jbl 10..G2 input signal board that causes no signal to go thru
A blinking light on the JBL 10" G2 input signal board can indicate a problem with the input signal. Here are some steps you can take to try to resolve the issue:
- Check the input cables: Make sure the cables are securely connected and there's no damage to the cables or the input jacks. Try swapping out the cables with a known working set to see if that resolves the issue.
- Check the source: Make sure the source device (such as a mixer or computer) is working properly and is sending an output signal.
- Check the input settings: Make sure the input settings on the JBL 10" G2 are correct. Refer to the manual for information on the correct input settings.
- Power cycle the device: Turn off the JBL 10" G2 and unplug it from the power source. Wait a few minutes and then plug it back in and turn it on.
- Check for firmware updates: Make sure you have the latest firmware installed on the JBL 10" G2. Refer to the manual or the JBL website for information on firmware updates.
- Contact JBL customer support: If you're unable to resolve the issue with the above steps, contact JBL customer support for further assistance.
If the issue persists, it's possible that the input signal board on the JBL 10" G2 may need to be repaired or replaced. In this case, you may want to consider contacting JBL customer support for information on repair options.
2/1/2023 5:46:55 PM •
JBL Audio...
Answered
on Feb 01, 2023
