20 Most Recent
Evenflo Aura Elite Travel System Wedgewood Stroller Questions & Answers
I recently purchased a Evenflo
There should be a lock above each rear tire. You can press these down or flip them up during regular use to lock and unlock the tires. In between the two tires on each rear tire- there should be a 'switch' with tread like things on it- just stick your toes under each one and pull up and they should flip up! And your problem should be solved!
My evenflo travel system will not stay open. When
Make sure that nothing on the bottom (near foot rest) is holding the stroller up from opening.
This is usually what happens.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
I have a car seat
Contact the company for a manual and they will mail one to you. They have to because you have to have your manual.
Looking into purchasing a used evenflo aura system
Hi I did some research online but the only thing I could find was this web link for you to tell the owner you want to see a picture of the system with the sticker on it with the manufacture date and model number so you can also look to see if there are any recalls on the unit. Hope this helps you some. Good luck!
Assembly instructions
You can contact EvenFlo directly, they will be happy to help you out:
http://www.evenflo.com/
Evenflo ParentLink Department: 1-800-233-5921
The latch that holds my
You should contact evenflo for a replacement part- or else you can order them if you follow the link - it takes you to the ordering page on their website for replacement parts- https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=5881485a&txSearchDOM=2/4/2004
How to install Evenflo Aura
do you have the instructions?? if not goto ww.evenflo.com to get them they give you step by step directions on how to install your car seat! If you have a problem with the base not being tight and floping all over then try rolling a towel tightly and putting in the dip of your seat and then fastening the base down, I usually put to towel down then put the clip on the seat belt a little short of being able to fasten it in, so then I can put all my weight on the base and clip the latch in! It just makes it so much easier and a lot tighter then it would have been in the first place
Help me with my car seat
You can check around for bases that fit the car seat at garage sales!!! Otherwise click the link- and you can order replacement parts for evenflo products directly from their web-site
How Do You Assemble The Carseat To The Stroller.
You need to remove the food/drink tray from the front of the stroller and then the carseat should fit right over where the tray once was- it will click down and stay secure just like it clicks when attached right into the base for the car. To take the car seat off- you simply take it off the same way as you take it off the base in the car!
I don't find one online, but I bet you could email the person that wrote this review:
http://www0.dealtime.com/xPR-Evenflo-Aura-Elite-Travel-System-Wedgewood~RD-229353361028
Need printable manual foe Chase Evenflo car seat 30621633
Possibly similar model manual from manufacturer:https://www.evenflo.com/on/demandware.static/-/Sites-evenflo-Library/default/dw009a2787/Instruction%20Manuals/25701061%20-%20Chase%20Select%20EN%20Jan17.pdfReplacement parts from manufacturer:https://www.evenflo.com/parts-accessories/car-seat/30621633/30621633_parts.htmlhttps://www.evenflo.com/support/instruction-manuals.html
https://www.google.com can be used to search for manuals, but unfortunately, the one I found appears to be a different model.
https://www.manualslib.com/products/Evenflo-Chase-4041185.htmlPerhaps you could contact a retail store or internet site that sells that particular model and ask for a copy of the manual.
