20 Most Recent
Evenflo Embrace - Rainforest Questions & Answers
Shoulder restraint adjustment
theres a way in the back of the carset to unhook your straps and feed them thru the higher level. just look inside the back of the carseat.
Installing
This is from the evenflo website:
https://plweb.evenflo.com/replacement_parts.aspx
If instructions are lost or missing please contact Evenflo ParentLink by calling 1-800-233-5921 or (937) 773-3971 or Evenflo now offers instructions that can be viewed and printed online. Please click on the "Replacement Parts" tab at our website and enter the model number and date of manufacture from your product. You will then see a list of replacement parts, which include the instructions. If you click on the words ?view instructions? you will be able to download and print them.
Hieght restrictions
yes. there is... basically it say 34" is for infant car seat. and weight is 22 lbs. Please dont forget to rate me, Hope this helps
Carseat straps
You can move it by pushing down on the flexible tab part of the seat base just above the box, but you don't need to move it at all in order to adjust the straps.
In order to move the straps I remove the clip side (the opposite side of the box), this removes in the same manner as the black box side, you just push down onthe flexible tab on the base; and run it through backwards, slide it into the next hole up, to make it larger run it back through the holes and click it back into the base in the back of the seat. This can all be done without disabling, The clip in the front of the seat must be unfastened but it will all fit through the holes in the seat to adjust the straps.
Need printable manual foe Chase Evenflo car seat 30621633
Possibly similar model manual from manufacturer:https://www.evenflo.com/on/demandware.static/-/Sites-evenflo-Library/default/dw009a2787/Instruction%20Manuals/25701061%20-%20Chase%20Select%20EN%20Jan17.pdfReplacement parts from manufacturer:https://www.evenflo.com/parts-accessories/car-seat/30621633/30621633_parts.htmlhttps://www.evenflo.com/support/instruction-manuals.html
https://www.google.com can be used to search for manuals, but unfortunately, the one I found appears to be a different model.
https://www.manualslib.com/products/Evenflo-Chase-4041185.htmlPerhaps you could contact a retail store or internet site that sells that particular model and ask for a copy of the manual.
I need instructions to assemble Evenflo Pack and Playyard.
Hello, Lenda -
The Evenflo company web site does offer instruction manuals for many Evenflo products:
There is a section on that web page, with the heading Playards & Portable Beds. Perhaps one of the model names listed there is the model name for your Pack and Playard.
If not, then I suggest you contact Evenflo Customer Service and ask for assistance regarding the locked side rail. This is the link to the Evenflo Contact Us web page:
https://www.evenflo.com/contactus
If you reside in the USA or Canada, you will find a telephone number to call. Otherwise, you can fill out the form on that page to send as an email message.
Best wishes.
