20 Most Recent
Initial IDM-7110 Portable DVD Player Questions & Answers
Will not play the entire DVD
your dvd reading head is out of sync open the lid hold the button that is pressed when the lid is close now with your finger move the head till the screen say's no disk that should be right to the center place a disk in and hold the button with your finger and notice a red light under the disk rotating pressing the next of fast forward button watch the light go to the outside of the disk . it should go right to the end without making a noise and read the entire disk if not keep moving the head till it does . your problem should be fixed there is no other reason to read only a part of the disk other then the disk it self is dirty.
NO DISC
I had the same problem , so nowing about electronics i did a test at the read eye . then i notice where the ribbion cable joins the reading eye looked like it was crack at the contact so i replaced the ribbion cable from a old dvd player I had sitting around it worked that was three weeks ago. the cable i,am talking about is white in color that it connected to the board and the reading eye . it crack is so small at the it can be over looked . this was caused by the head moving back and forth.over time .
No sound whatsoever on my dvd player.
These units have a remote which provides controls not on the player itself. Be sure to check that the mute is not on. The other obvious question (but it still needs to be asked) is have you checked the volume control setting. When you move the control do you hear static or anything over the speakers which could indicate a bad volume control. Have you checked audio with headphones? If you have sound with headphones then you may have a loose connection in the speaker wiring or the headphone jack may be malfunctioning.
Won't load DVD for Initial IDM-7110
First check and see what is happening inside. Take something small and stick n the lock mech, which is the hold that a small part of you top to the player sticks in to tell the unit that it is closed. See if the lense light up and moves up and down and also see if it moves forward a bit and back to start position. If player does not do any of this then with fingers move lense down line abit to see if anything is obstruting path. You can move all the way down then place DVD in and try again
