20 Most Recent Scotsman Ice Maker 600LB CM3 30inW Commercial Cubed Machine Questions & Answers
Refrigeration light is on, not making any ice.(scotsman cm3)
There can be a few reasons why your Scotsman DCE33PA1SC ice machine is not making ice, even though it has power and water:
  1. Thermostat: The thermostat controls the temperature inside the machine. Make sure that the thermostat is set to the proper temperature and that it is functioning properly.
  2. Water inlet valve: The water inlet valve is responsible for letting water into the ice maker. Make sure that it is functioning properly and that it is not clogged with debris.
  3. Water pump: The water pump is responsible for circulating water through the ice maker. Make sure that the pump is functioning properly and that it is not clogged with debris.
  4. Water filter: Make sure that the water filter is clean and not clogged.
  5. Control board: The control board controls the operation of the ice maker. Make sure that the control board is properly connected to the power source and that it is not damaged. It's possible that the control board is malfunctioning, which can cause the ice maker to not work correctly.
  6. Refrigerant levels: low refrigerant levels can cause the evaporator to freeze over, which can affect the ice production. Make sure the refrigerant level is adequate.
It's best to consult the user manual or to contact a professional technician to diagnose the problem, as the issue could be caused by a number of things and it's important to troubleshoot it correctly
1/22/2023 8:38:02 PM • Scotsman Ice... • Answered on Jan 22, 2023
My scotsman cm universal service controller keeps going and neverr shutting off?
The CM Universal Service Controller (USC) on a Scotsman CM3 30inW Commercial Cubed Ice Maker is designed to monitor and control the various functions of the machine. If the USC is not shutting off, it could be caused by a few different issues:
  1. Power supply: Make sure that the ice maker is properly plugged in and that there is power to the outlet.
  2. Control settings: The control settings may have been set incorrectly. Make sure that the control settings are set correctly and that the machine is in the proper operating mode.
  3. Control switch: The control switch may be faulty, preventing the machine from shutting off. If this is the case, the switch will need to be repaired or replaced.
  4. Thermostat: The thermostat controls the temperature inside the machine, if it's not functioning properly it may cause the machine to never shut off. A faulty thermostat will need to be repaired or replaced.
  5. Control board: The control board may be faulty, preventing the machine from shutting off. If this is the case, the control board will need to be repaired or replaced.
It's best to consult the user manual or to contact a professional technician to diagnose the problem, as the issue could be caused by a number of things and it's important to troubleshoot it correctly. The technician will be able to run a diagnostic test to determine the root cause of the problem and make the necessary repairs.
1/22/2023 8:28:10 PM • Scotsman Ice... • Answered on Jan 22, 2023
Pump and valve no working
If the pump and valve are not working on your Scotsman Ice Maker CM3 30inW Commercial Cubed Machine, there are a few things you can try to fix the issue:
  1. Check the electrical connections: Make sure that the pump and valve are properly connected to the power source and that there is no damage to the wiring.
  2. Check the water supply: Make sure that the water supply to the machine is turned on and that the water pressure is sufficient. You can check the water pressure by using a gauge on the incoming water line. The pressure should be between 20 and 120 psi.
  3. Check the water inlet valve: The water inlet valve is responsible for letting water into the ice maker. Make sure that it is functioning properly and that it is not clogged with debris.
  4. Check the pump and valve for clogs: Make sure that the pump and valve are not clogged with debris, clean it if needed.
  5. Check for leaks: Inspect the machine for any signs of leaks and repair them as necessary.
If none of the above steps resolve the issue, it may be necessary to replace the pump and/or valve. It's best to consult the user manual or to contact a professional technician to diagnose the problem, as the issue could be caused by a number of things and it's important to troubleshoot it correctly.
1/22/2023 8:19:46 PM • Scotsman Ice... • Answered on Jan 22, 2023
Why is the off light on on my scotsman ice machine
There could be a few reasons why the "off" light is on your Scotsman ice machine:
  1. Power Supply: The first thing to check is that the machine is properly plugged in and that there is the power to the outlet.
  2. Control Panel: The control panel may have been set to "off" mode manually. Make sure that the control panel is set to "on" mode.
  3. Control Switch: The control switch may be faulty, preventing the machine from turning on. If this is the case, the switch will need to be repaired or replaced.
  4. Thermostat: The thermostat controls the temperature inside the machine, if it's not functioning properly it may cause the machine to shut off. A faulty thermostat will need to be repaired or replaced.
  5. Power Outage: If there was a power outage and the machine lost power, it may have entered into a "safety" mode, this feature stops the machine from turning back on automatically after power is restored. Wait for a few minutes and then try to turn the machine back on.
1/22/2023 8:16:45 PM • Scotsman Ice... • Answered on Jan 22, 2023
Scotsman ice machine flashing 2 red lights cme256ws
The blinking of 2 red lights on a Scotsman ice machine CME256WS typically indicates an error code. The most common cause of this error code is low water pressure or a problem with the water supply. You should check the water pressure by using a gauge on the incoming water line. The pressure should be between 20 and 120 psi. If the water pressure is adequate, you may have a problem with the water inlet valve, which is responsible for letting water into the ice maker. If that is the case, you may need to replace the valve. You can also check for clogs in the water filter or water supply line, and ensure that the water shut-off valve is open. If all the above steps are done and the problem persists, It is recommended to call a qualified technician to inspect the machine and diagnose the issue.
1/22/2023 8:12:01 PM • Scotsman Ice... • Answered on Jan 22, 2023
How do I fix the max harvest time shutdown
The ice sensors are not sensing the ice fall.Wave your hand in front of them the bin full light should blink.If it doesnt clean eyes and conectors.If it still doesnt blink change them they are bad.
6/15/2022 4:31:47 PM • Scotsman Ice... • Answered on Jun 15, 2022
2answers
Check the dump valve if water is seeping through the dump valve then the water inlet valve will be adding water to sump all the time to replace water lost. Now if water is running over sump into ice bin then look at water inlet valve.
10/10/2016 4:10:10 PM • Scotsman Ice... • Answered on Oct 10, 2016
CME456AS-1C BIN FULL LIGHT ON BIN EMPTY MACHINE RUNS FOR 1 MIN THEN STOPS
clean the ice sensor on either side of the ice platen and just past the water trough. gently pry the sensor on each side out of their plug and work wiring out until you can get to the two led lights and clean scale off. limestone scale builds up and blocks the sensors.
10/1/2014 12:44:15 AM • Scotsman Ice... • Answered on Oct 01, 2014
How often should you clean the ice maker?
it depends on the quality of water in your water supply. If you get scale buildup easily, you need to descale and sanitize it as often as each month, if scale buildup is minimal, descale and sanitized every 6 monthes. I always nickel safe scale remover and calgon sanitizer. If in doubt, consult the manufactures recommendations.
10/1/2014 12:30:04 AM • Scotsman Ice... • Answered on Oct 01, 2014
Where is timer located in scotsman icemachine cm3
In the control card circuitry.
10/1/2014 12:03:24 AM • Scotsman Ice... • Answered on Oct 01, 2014
Ice machine harvest two times and shut off
These unit time freeze time and harvest times and keeps track of them. If your freeze time exceeds 35 minutes or harvest time exceeds 3 minutes, it will place unit in lockout. The biggest cause for excessive time to harvest is the harvest valve not functioning properly, and undercharged unit or a dirty condenser. The most probable cause is a dirty condenser. Under charged units can be determined by checking compressor outlet temperature while running, it should be 150 to 190 degrees depending on atmospheric conditions present. If it is harvest valve, the downstream temperature will stay at or near compressor discharge temperature. It should cool down to ambient temperature in a few minutes after freeze cycle begins.
9/30/2014 1:08:35 AM • Scotsman Ice... • Answered on Sep 30, 2014
I have a scotsman cme656 the bin sensors where bad, bought a new set install sensors. They would no sense ice dropping , put my hand in shoot light blinks, only when my hand is within 1" or 2" from le
check the condition of the connection for the sensors. If corroded or not connecting properly, the sensor has limitted range for ice sensing.
9/30/2014 12:58:22 AM • Scotsman Ice... • Answered on Sep 30, 2014
Water keeps running on cm3
Replace the ice thickness sensor hanging on the front of the evaporator plate. when you turn the power off and back on factory default is to go to harvest first. if the ice thickness sensor dose not sense the ice is thick enough then it will not go into a harvest. before you replace the sensor take it loose from the evap plate and drop it into the water sump tray if it goes into a harvest then replace the board. if not then replace the sensor.
9/26/2014 7:12:59 PM • Scotsman Ice... • Answered on Sep 26, 2014
How do i get a service manual?
The bin sensor eyes need to be cleaned or replaced. First remove the front cover then remove the white plastic ice deflector shield. Now you should be looking at the evaporator plate look down you will see the water sump tray full of water in that tray is a black plastic grate that when the ice is harvested it drops and hits the tray keeping it from falling in sump tray PULL it OUT. now just behind the sump where the ice falls through opening on the left and right sides is where the ice full bin eyes are you can pull them out side ways there is plenty of wire so you can pull them up to where you can clean them with a soft cotton cloth with scotsman cleaner. Now for a manual goggle scotsman service manuals you can get a PDF file.
9/26/2014 6:47:50 PM • Scotsman Ice... • Answered on Sep 26, 2014
How many volt is the c0630ma-32a needs ?
208-230 volt 60HZ single phase.
9/26/2014 6:37:04 PM • Scotsman Ice... • Answered on Sep 26, 2014
How to change cube size control
If I remember correctly on the control board there is two prong bias setting you can change. It looks like three prongs side by side and depending on where you place the jumper between the prongs you have up to 7 cube setting adjustment you can make. You can go to Searspartsdirect.com and get a manual for this I think with your model number. The manual has the appropriate jumper positions. I have seen some unit the jumper positions were actually listed on the control board itself.
9/26/2014 5:36:36 PM • Scotsman Ice... • Answered on Sep 26, 2014
Light blink twice
Which light is blinking the water or the refrigeration light this info will help
4/24/2014 11:08:30 PM • Scotsman Ice... • Answered on Apr 24, 2014
Refrigerators Logo
58 questions posted
Top Scotsman Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
MasterTech
MasterTech
vince
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Scotsman Refrigerators
Most Popular Question
  • Refrigerators
