20 Most Recent True Refrigerated Sandwich Prep Table 72" 30 Pan Questions & Answers
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
https://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
https://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
https://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
True... | Answered on Jun 25, 2017
Have the unit leak test after pressurizing with "Nitrogen"
True... | Answered on Jun 27, 2015
What kind of noise? Where is the noise coming from? Inside the unit or where the compressor is?
This will help You. I had to replace compressor. It died due to the 100% clogged coils. REPLACING COMPRESSOR TRUE AIR BEER COOLER R134A
This compressor burned out due to lack of maintenance, condenser coils were clogged 90%. compressor overheated and blow out. I made video how To change compressor and filter dryer. Its a beer cooler. REPLACING COMPRESSOR TRUE AIR BEER COOLER R134A
Either your coil is blocked with paper or wrap, or you have a refrigerant leak in the coil and the little bit of gas that's left is flashing as it enters the coil. Make sure that the cooling coil and condenser is clear and the fans are running. That's all you can do without refrigeration tools. Good luck and hope this helps
True... | Answered on Oct 18, 2014
Cold Tech gaskets can be obtained from Case Parts Co. 800-421-0217 or RHS Parts 800-537-8300, per jimex corps final technical spec. sheet. I hope this helps.
True... | Answered on Apr 26, 2014
Keep the prep top table pans covered when not in use. Never leave empty holes where pans should be. If the pans are empty put a couple of inches of water in them to keep some heat load there. Check the door gaskets and door seal on the base doors. Make sure the thermostat is set on number 5. If all of this checks out probably need a new thermostat, but if it's erratic I suspect you will find it's one of the former problems.
True... | Answered on Mar 30, 2014
Hi
Sounds like you are correct, unless the door seals are not in good order, air leaking in can fool the thermostat.
If it has a top section that the pans for pizza ingredients sit in check that the airways are clear and that the tins and lids fit properly.
Regards
Gordon
True... | Answered on Apr 27, 2011
Refrigerators Logo
22 questions posted
Top True Refrigerators Experts
Dennis Boxerman
Joe Palazola
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
True Refrigerators
  • True Refrigerators
Most Popular Question
true prep table won 39 t hold
  • Refrigerators
