20 Most Recent U-Line Echelon Series 2075DWRRSS Refrigerator Drawer w/ Three Piece Organizing System: Stainless Ste... Questions & Answers
The compressor on my 2075 DWRRB unit stopped. Confirmed power to the unit (interior light is on and "On/off" switch is on. Is there a reset button on this unit? Sometimes when a ref rig compressor q
I believe most compressors use a self resetting thermal switch which reset when the temperature returns to normal. It could be bad. If you have access to a volt meter you can verify you have voltage at the terminals of the compressor, work backwards from there.
12/6/2014 8:15:37 PM • U-Line Echelon... • Answered on Dec 06, 2014
Thermister open- U Line 2075DWRRSS under the counter two drawer refrigrater
Can you get hold of a thermistor?
4/22/2014 9:28:40 PM • U-Line Echelon... • Answered on Apr 22, 2014
Thermister open
replace the thermister
4/20/2014 7:09:03 AM • U-Line Echelon... • Answered on Apr 20, 2014
2answers
Need to take off u-line 2075 drawer refrigerator doors - how?
Hi
Frost in u-line drawer dwrr models happens because of 3 things. The most common is that the drawer wasnt sealing properly. At the ends of the slides you see a white plastic end. This is called door closers. Remove your drawers,Unplug the top drawer. Then remove the closers on all slides. Take a small screw driver then push on the top of the slide. You should see a piece of the closers. While pushing down pull the ends out.You see the hook and spring, sometimes the hooks get off track and keep the drawer from closing. By keeping them out this should help. Also if you have vegetables keep them in sealed containers. The 3rd thing is you have the display set at 34 and this will cause the unit to run 100% of the time. Recomend 36 degrees.
6/9/2012 3:01:59 PM • U-Line Echelon... • Answered on Jun 09, 2012
Controle pannel works refrigerator does not cool
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/26/2011 12:31:40 AM • U-Line Echelon... • Answered on Sep 26, 2011
Uline 2075DWRRSS stopped working.
Sounds like you have found the source of your problem. Yes,tighten all wires and wrap them with a zip tie.
8/3/2011 8:44:17 PM • U-Line Echelon... • Answered on Aug 03, 2011
3answers
My Uline Echelon refrigerator drawer
The doors should be proper close.If the unit is remaining open due to black plastic kick screen at floor level , then it can cause the leaking.But its rare that black plastic kick screen at floor level is causing the leak.But still inspect that black plastic kick screen area and see if any inside air is loosing/ leaking from there.--------- Other possibility can be vent clogged in the unit, causing the water to leak inside instead or drain the water from drain line.--------- In that case try one thing.Try manual defrost procedure and see if that helps:---
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal setting. Then check.-------- This will help.Thanks.Helpmech.
7/7/2011 12:30:46 AM • U-Line Echelon... • Answered on Jul 07, 2011
2answers
Refrigerator stopped working Followed
Hi! It sounds as if, after you followed everything recommend in the Owners Manual and it still doesn't work, than either one of the relay circuits to the compressor or the compressor itself, has failed. As far as troubleshooting this problem is concerned, it's a process of elimination. Check the circuits first with a multimeter. If you have power on the incoming side of the relay circuit, but none on the outgoing side to the compressor - it's a circuit problem. If you have power on both sides, then but the compressor fails to turn ON, it's the compressor.
U-Line has discontinued this model, but parts are still available thru one of their service centers around the country.
Below is a link to there Customer Service Contact page. There you can locate a service center near you.
http://www.u-line.com/customer/contact.cfm
Hope this helped you. Please let me know. Thanks.
6/15/2011 3:46:56 PM • U-Line Echelon... • Answered on Jun 15, 2011
How do you get the thermastat to stay at a lower
What model do you have?
7/27/2009 4:27:02 AM • U-Line Echelon... • Answered on Jul 27, 2009
U-Line Echelon Series 2075DWRRSS Refrigerator Drawer w/ Three Piece Organizing System: Stainless Ste... Logo
27 questions posted
Top U-Line Refrigerators Experts
Kardoc
Jorgie  the...
Jorgie the...
ADMIN Andrew
ADMIN Andrew
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • U-Line Refrigerators
Most Popular Question
refrigerator stopped working followed
  • Refrigerators
