20 Most Recent Hoover HCA391FFK Bottom Freezer Refrigerator Questions & Answers
I have a hoover
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
8/24/2011 10:31:33 PM • Hoover HCA391FFK... • Answered on Aug 24, 2011
Freezer cold fridge warm
sounds like the evaporator in the freezer section is iced up and you need to see if the defrost section is working correctly,then as for the warm refrige side,it sound as if the vent damper door is frozen shut or the cold control in the refrige isn't opening it to let cold air into the refrige from the freezer,if its frozen take a hand held hair dryer and remove the vent grille over it and defrost it and then check to make sure the control opens and closes it as you adjust its control in the refrige
4/26/2010 12:41:16 PM • Hoover HCA391FFK... • Answered on Apr 26, 2010
We have a Hoover No frost
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
4/16/2010 11:58:13 AM • Hoover HCA391FFK... • Answered on Apr 16, 2010
FRIDGE NOT WORKING
try checking your evap fan motor if it is not running you will need to check to see if it is getting power if it is then you will need to replace the motor also check your settings make sure th freezer setting is not set over half way the freezer setting controls the air flow to the ref
7/3/2009 10:21:45 PM • Hoover HCA391FFK... • Answered on Jul 03, 2009
Fridge compartment not cooling ....
verify is in the air vent to fridge isn't obtructed by food products also there's a vent in the the freezer that if obstructed no cold air comes in.
4/21/2008 6:26:10 PM • Hoover HCA391FFK... • Answered on Apr 21, 2008
I have a hoover fridge model HE505UF am chasing the freezer basket and the fridge lamp anyone knows where I can get one
Most spares are to be found here; https://www.espares.co.uk/browse/at1084ma107/fridges-and-freezers/hoover
8/17/2023 6:13:58 PM • Hoover... • Answered on Aug 17, 2023
Hoover HFLE54XK Fridge. Condensation in my Hoover under the counter fridge.
Goodness, that is tiny even for a UK fridge! https://www.rjelectrics.net/product/hoover-hfle54xk-freestanding-under-counter-larder-fridge-silver/ The problems are two-fold
  • Your fridge is basic and has no circulation fan.
  • The air in your home is too humid.
Try something like this from Screwfix UK to soak up and condense the moisture. Best advice though is get a new one and sell that one on Marketplace or Kijiji. https://www.screwfix.com/c/heating-plumbing/moisture-absorbers/cat14640001 ..
8/2/2023 9:28:19 PM • Hoover... • Answered on Aug 02, 2023
Hoover blade brush won't rotate. brush clean, belt good
If the brush on your Hoover Blade vacuum cleaner won't rotate, there are a few things you can check to try and fix the issue:
  1. Check for obstructions: Check the brush roll for any obstructions like hair, string, or debris that might be wrapped around it. Remove any obstructions you find.
  2. Check the belt: Even if the belt looks good, it might be stretched or damaged. Check that the belt is tight and not slipping. If the belt is stretched or damaged, replace it with a new one.
  3. Check the motor: The brush roll is powered by the motor, so if the motor is not working properly, the brush won't rotate. Check that the motor is working by turning on the vacuum and listening for a humming sound. If you hear a humming sound, the motor is working. If not, there may be an issue with the motor that requires professional repair.
  4. Check the brush roll bearings: If the bearings on the brush roll are worn or damaged, it may cause the brush to stop rotating. Try rotating the brush roll by hand. If it doesn't turn smoothly, the bearings may need to be replaced.
If none of these solutions work, it may be best to take your Hoover Blade vacuum cleaner to a professional for repair.
5/1/2023 6:46:37 PM • Hoover... • Answered on May 01, 2023
Hoover HV9 9H1075 Fridge. How to change the LED light please?
Question edited for clarity. You may be able to repair the board. If not, the whole module is replaced. https://www.google.com/search?q=Hoover+HV9+9H1075+Fridge.+replace+LED+light
2/7/2023 6:29:09 PM • Hoover... • Answered on Feb 07, 2023
Loud buzzing from Hoover Fridge.
You are not alone! https://www.google.com/search?q=hoover+hsc574s+buzzing+noise The condenser coils are underneath and it the perfect place to attract fluff, especially if you have animals. On mine, you open the bottom door and pull off the kick grill. There is also a panel on the back at the bottom that hides the compressor. That is an easier place to get the vacuum cleaner crevice tool in. You buzzing may be overheating, but it may also be a sign of impending failure.
Cleaning Your Fridge or Freezer - Advice Centre - Hoover ...
https://service.hoover.co.uk > advice-centre > cleaning-... Routine cleaning tips. Your fridge freezer should be regularly cleaned to ensure good hygiene practice. You should take care to remove obvious food debris, ...
1/22/2022 7:29:26 PM • Hoover... • Answered on Jan 22, 2022
How to change led light in hoover fridge
remove plastic cover then remove bulb
2/14/2021 4:28:23 AM • Hoover... • Answered on Feb 14, 2021
My 15 years old Hoover contour both freezer and fridge not cold enough even I switched on to the max
Refrigerator: Freezer not cold enough. Defrost system problems, dirty condenser coils, fan failures, leaky door gaskets or control problems can lead to your freezer not getting cold enough. ... The frost buildup blocks cooling air paths through the evaporator so the freezer doesn't cool well. https://www.searspartsdirect.com/diy/symptom/refrigerator-repair/1234589/freezer-not-cold-enough/ref0002
5/14/2020 10:16:10 AM • Hoover... • Answered on May 14, 2020
How old is my orchid Hoover 400litre fridge?
The Hoover Orchid is actually a rebadged Phillips Fridge. It would be over 20 years old now. I used to fix these in the mid to late 90,s
9/23/2019 2:14:36 AM • Hoover... • Answered on Sep 23, 2019
Hoover HCA391FFK Bottom Freezer Refrigerator Logo
8 questions posted
Top Hoover Refrigerators Experts
vince
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Hoover Refrigerators
Most Popular Question
fridge not working
  • Refrigerators
