20 Most Recent
Saeco Incanto Classic Espresso Machine Questions & Answers
No Power
Take off the water tank and loosen the two screw in the chassi. Lift the chassis little and take off the back piece.
If your machine is new model then you have a round boiler on the right side, put in a finger between the chassi and the boiler, you have two thermostat fuse you have to reset.
If you have a old model the you have a fuse on a wire, if you not find any wire with fuse, then you have to take off the top of the machine. You will then see the power card, find the fuse on it and check it.
Hope this will help you.
Best regards
/Mirran
Saeco Incanto Deluxe, ventilate problem
VENTILATE ERROR at 27,211 brew cycles on 12/31/22. I read that a stuck Flow Meter might be the cause of the error. A Factory Reset was suggested, so I did that and the Ventilate Error cleared, but it returned on the 1st brew cycle. Since the pump works fine and I had nothing to lose, I continued Ventilating and let the water tank empty, so it really needed to Ventilate. Started with 1 liter of the hottest tap water available, I allowed the tank to empty and then Ventilated using 1.5 liters of boiling water. The Flow Meter must have cleared because I was offered Hot Water or Steam. In the end, the machine is working fine. I had to re-program all of the settings because of the Factory Reset, but my machine lives on. 2023 here we come.
Incanto de Luxe always tells me there are no beans in container
I do have the same problem.
I have removed and cleaned the grinder mechanism.
Being an electronic technician I did have a look and tried to find what method they use to detect that the new beans reservoir is empty and I did not see any kind of detector.
I suspect that they monitor the motor current to do this. If it is so would'n it be possible to desable this fonction since it is more then evident when the reservoir is empty or about to be?
Any body knows how they do monitor the status of the new beans reservoir?
Coffee beans empty message with enough coffee
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be to the back side of the drop chute.
Once that is cleared go to the bean hopper. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
Machine won't grind beans "says beans empty" it is not
After a tons of browsing and debugging finally I got the real solution to my similar problem with a Saeco Minuto HD8763 coffee machine: the root cause was a bad hall sensor and a weak magnet at the
grinder toothwheel (the left magnet whcih was removed from it's original place). The upper one was okay and down under there is the replacement magnet which I made from a piece of HDD neodymium magnet and glued to fix it.
The original hall sensor was marked as "210k 3491" ("HAL506K" based on some other service manuals) and the new one was a cheap non-smd but same size, unipolar "TLE4905" type.
'dregdrawer full' message but not
HI
Are you leaving the machine on when you empty the dredge drawer? There has to be power for the computer to see that the dredge drawer has been removed. Leave it out at least 15 seconds, so the computer thinks you emptied it. This should clear the message.
Water in tank but water light on
First, I'm not a Saeco technician. Though I've worked on similar Saeco models.
*** The following is for information only. You should always call your vendor for service, as opening this machine will void warranty.***
- Water not getting to machine or not sensing that the water tank is already filled.
* There usually some type of float near to middle of the water tank. It's usually white or colored plastic. This 'float' needs to move freely up-down to 'sense' the filled tank. clean the tank and shake it -note the movement of this float. It will need further cleaning if it's stuck (or you will have to replace tank if it's crudded up).
* Re-install tank and fill with filtered water. Turn machine off, count to 15 then turn on again. This usually turns on pump to add water to inner tank. If this does not happen then there is a CPU problem. If it does hums for 5-10 seconds then goes off but no heating then the pump may have an air bubble in line. Try the turn off and on method several times (up to 5) to get the water flowing. If it's still not working then there is a clog in the pump and will need service and/or replacement.
* Did you change water source? Since this is a table top machine in which you fill the water tank. Try to use filtered (bottled ok) water. Do Not use Distilled or 100% pure water as this type of water will eat out the metals from your machine! Some places use a water softener as it tends to be better for the machine long term (years).
* Still got problems? Check with vendor or MFR for service or replacement. Most machines of this type do not have serviceable parts or adjustments.
Aloha, ukeboy57
Water light not going out, even when full. Not able to make coffee
the water tank has a float inside, the float has a magnet. the machine senses the position of the magnet and indicates water ok/not. sometimes the magnet rusts inside the plastic casing, renders it less magnetic so it wont work. or the float is missing- fell out while you were cleaning the tank. you will need a new magnetic float to fix the problem.
Hi, I a problem with my Saeco s-class incanto
Try this, when you run the hot water cycle to prime machine and it stops putting out water push in on the knob if that works then replace the tap rod assembly or the whole steam valve assembly.
