20 Most Recent
Hoover F5870-900 SteamVac Vacuum Questions & Answers
I NEED THE INSTRUCTIONS ON HOW THIS MACHINE IS TO
Hi m-works.
I would, too; but Hoover's website no longer makes manuals available for some models, including mine.You might luck out. Try Hoover.com/manuals and put in the mod no. & give 'em a try
Download manual
diagrama dvd lg mod dvd7811n fuente conmutada al encender aparato truena el ic oscilador y no se cual es el numero del ic
How can I remove the pet hair that is trapped in
Generic comment.
If the parts aren't glued in, they must be snapped in or fastened with screws. You say there are no screws - try unsnapping.
I think id try a coat hanger first with the help of air pressure if you have access or a second vacuum.
Pet hair is definitely an annoyance in these machines. I know from experience. I guess that is why the instructions generally say to vacuum first! I learned my lesson with the coat hanger/air/vacuum method. Who needs stupid instructions anyway!
I hope you get your machine unclogged.
a
Hoover model 5870-900
you dont have the lid on correctly, if you can lift the lid up, then you have it on incorrectly.
How do you remove the brushes on a hoover steamvac
Hoover makes running changes on these style steamvacs without changing the model numbers. One of the following or both.
Four tabs (opaque/white in color) about a 1/4 of the way in from each corner of the plastic brush block that need to be depressed to release the block. (most common) Slide the brush as far out as you can with out putting much tension on them and simply depress them. These are often brittle take great care not to bust them. Gently wiggle the brush block to release the drive spindle.
Two large tabs at either end of the brush block. Slide the brush out as far as you can (release previously mentioned tabs) and then wiggle gently towards the front and the back of the machine. The top tabs (generally black) will catch on the outer eges and be very easily seen and pressed with your finger.
To clean them simply drop the assembly in a bucket of soapy water overnight (no metal to rust nothing to corrode) then clean with hose. I carefully use a pressure washer on mine.
To reinstall brushblock make sure drive spindal is on correct side by lining up hole with spindle, and gently push the block into place while making sure the guides on either end are correctly aligned. All done, go clean some carpets.
Best of Luck
Kenmore central vacuum system
There is two possible causes. One you could be plugging in the end of the hose wrong. Make sure the hose end is securely in and in the right position. Second it could be a malfunctioning switch in your handle. Here is a site with a variety of different hose handle switches.
www.mountaincentralvac.com
Hoover F5909-900...can't find manual. Can you
Check out Hoover US website on:
http://www.hoover.com/CustomerService/Manuals/Default.aspx
There's a telephone number you can call if you can't find the user manual you are looking for.
My spin scrub does not suck up dirty water
When your Hoover spin scrub is not sucking up water, the most common problem is the clear round cap located on the suction nozzle is not closed. See pic. Also check the rubber cap on the dirty water tank.
How do you replace Hoover Handle Release Pedal on
The handle pedal is snapped in to the base, where it pivots.
The pedal needs to be pried away fron the base, exposing the pivot pin to release it for removal. On your model, you will likelly have to remove the lower handle from the base (where it pivots) to get room to release and replace the pedal.
