20 Most Recent
Hoover Windtunnel Supreme U5280-900 Upright Vacuum Questions & Answers
Plugged hose on Hoover Windtunnel
you will have to remove the bottom cowling under the vaccum cleaner there are 4 phillips head screws one at each corner when you turn over the vaccum cleaner, take this off and remember how it goes back on. in the area where the hos is there will probably be a clog at that point. remove this and pull hose off and make sure it is not clogged farther up the hose, reinstall and check
5/4/2014 12:49:41 AM •
Hoover...
Answered
on May 04, 2014
We have a Hoover WindTtunnel,
What you have is a bad thermal fuse. The fuse is located on a motor wire inside the motor compartment,( part # 28382093, msrp $ 6.59). A good deal of disassembly is required to access this part. Bypassing is NOT recommended.
8/16/2011 10:23:10 PM •
Hoover...
Answered
on Aug 16, 2011
The suction has decreased by about 50%. The brush
Check that there is nothing blocking the hose and that there are no obstructions around any of the filters, clean and replace filters too if possible. If you still find you have less than optimum suction , you may need to replace your motor. But it sounds like there may be a blockage or an air leakage somewhere in the unit.Good luck.
6/7/2010 1:58:22 AM •
Hoover...
Answered
on Jun 07, 2010
The on off swtich doesn't work on our hoover
If its just the switch then by all means it can be repaired or replaced. If it needs replacement and the part is not available, you could replace it with a generic switch which may need some modification. Alternatively you can bypass the switch with the wiring and turn the machine on and off at the wall outlet.
Best wishes,
Graemevm
6/6/2009 12:36:36 PM •
Hoover...
Answered
on Jun 06, 2009
Vacuum will not shut off
Either the switch has a contact inside, or the wiring in the harness to motor are making contact.
This can be verified using a multimeter , preferably reading continuity (Ohms) on switch contacts, with power disconnected, that is safer than reading voltages.
This will tell if responsible is the switch or the wiring harness.
5/9/2009 12:10:21 PM •
Hoover...
Answered
on May 09, 2009
Hoover u 6401 bought v
You will need to get another belt, it's common that the people pulling the parts are so busy, that they sometimes mistakenly pull the wrong part, or the wrong part number was given, even a misprint in the manual. Needless to say, it seems that you don't have the correct belt. There is no adjustment for belt tension, so it has to be the wrong belt.
1/20/2009 2:44:05 AM •
Hoover...
Answered
on Jan 20, 2009
Installing belt
here are the step by step instructions from the owners manual for your machine.
Disconnect cleaner from electrical outlet.
WARNING: Agitator brush roll can start suddenly. Unplug cleaner before turning it over. Replacing Flat Belt Place handle in low position and turn cleaner over so bottom side is facing up. Remove the 6 screws as shown with a Phillips screwdriver. Lift off bottom plate.
Replace belt if it is stretched, cut or broken. To check the flat belt. Removing Bottom Plate Removing Belt Positioning Belt Remove used belt from large pulley and discard. Reposition bottom plate and 6 Phillips head screws. Tighten screws securely. Insert agitator brush roll through belt and position belt in groove (A) on agitator brush roll.
Inspecting V-Belt
The V-belt is designed to last for a long time and
is not normally replaced. However, if the V-belt is
cracked, gouged or broken, it should be replaced.
Slide flat belt off large pulley.
To remove V-belt, slide back of belt over pulley (A).
Then firmly pull on belt and “snap” it out.
Discard used belt.
To install new belt (with lettering on outside of
belt), slide back of belt over pulley and pull front of
belt toward groove next to pulley. Belt will “pop” into place.
Flat Belt: What to Buy
Use only genuine HOOVER belts with your
cleaner. When purchasing a new belt, ask for
Flat belt - HOOVER part No. 40201-271.
V-Belt: What to Buy
Use only genuine HOOVER belts with your cleaner. When purchasing a
new belt, ask for V belt - HOOVER part No. 40201-200.
If you can't get the answer from this post, send me a message and I will try to walk you through this. I hope it helps.
1/20/2009 2:39:54 AM •
Hoover...
Answered
on Jan 20, 2009
