20 Most Recent
Bunn NHBX-B Contemporary 10-Cup Home Coffee Brewer, Black Questions & Answers
I have a bunn coffee
What a scam. I am a professional electronic technician trained in safe practices in electrical work and they won't sell me the replacement switch. I will source a suitable replacement from one of the big electronics supply catalogs. This will be my last Bunn coffeemaker.
My Bunn NHBX-B model, water comes out of tank luke
IF YOU are good at repair,
Before ordering any parts, (And by the way the part you listed is the hi-limit thermostat) get a volt meter and check the heating element, thermostat and loose/burned wires or wire connectors.
Note: Thermostat is more money, more like $26 - $47.
Good luck.
I have a Bunn NHBX-B
First thing is to look at the spray head and make sure all the holes are clear. Take your delimeing tool and push it in the hole as far as you can where the spray head was, and push it in and out about 5 times. Now leave the spray head off, and with the unit unplugged, pour 10 cups of water in the unit and let it flow out. Repeat this 2 more times. Replace the spray head and plug the unit back in. Wait 30 minutes and then make a pot of coffee.
New Bunn NHBX takes about
It sounds like you might have a problem with the water tubing. If you will call Customer Service at 800-352-2866 we will be happy to assist you with this issue.
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
