20 Most Recent
Quicksilver , Mac ATI RADEON 7000 64MB DVI/VGA Video Card (PCI) (p/n 1024-9C02-00-SA)-Limited Supply Graphic Card Questions & Answers
I have a quicksilver throttle control side mount
from what i have learned... (i have the same problem), is that it will beep for 2 reasons that i know of, water or oil. check your waterflow out of the motor, it should be ripping right out with good force. If not, your looking at a cooling problem. Check the impeller, its located in the lower unit of the motor, have you run the engine out of water? or even tuned the engine over quite a bit out of water? if so replace the impeller asap! If its not the cooling its an oil problem. In a lot of cases its an oil sensor, if so replace it fairly cheaply, or it could be that the injection system isnt working properly... this is an expensive fix the engine has to be completely broken down, what i did was just syphon the oil out of the reservoir, and mixed the oil into the fuel! If it comes down to it just mix it 50:1. that way you dont ruin your engine, as far as the beeping, it wont stop it unless its that stupid sensor, i guess just unplug it?
NOo tEnGoO ViDeOo nEsEsItOo EL INTaLaDor DE
go on line and type the following information
quicksilver mac ati radeon 7000 dvi/vga error
n0o tEnGoO ViDeOo nEsEsItOo EL INTaLaDor DE ViDeOo
enter
this will see if anyone else has every seen these errors before
my own filling is a software and hardware compatibility error
rod
ps mac are the easys system to troubleshoot and repair and i love working with them in the school system
best of luck
rod
Vaio graphics card upgrade
First off, it needs to be a desktop. Make sure the Motherboard has a PCI-e slot, and that the card is seated properly. Also make sure that you screw in the metal tab in properly or the card could come loose.
Laptop crashes every time I play a video game
Have you made 100% certain that you have the right driver. The laptop versions of nVidia cards are different to their desktop counterparts.
They use the suffix of "go" and the drivers normally have to be obtained from the laptops website.
Kernal panic
To reset nvram,
Press "cmd alt O F" at startup
Then enter:
reset_nvram (press enter)
reset_all (press enter)
A kernel panic can come from a lot of things (peripherals, corrupted file, or damaged hard drive or memory). The best is to check in the log file what caused the kernel panic, or to proceed step by step, checking one thing after the other, until the problem is resolved.
Video adapter not listed in Device Manager
http://ati.amd.com/support/driver.html
go to this site and enter the details for your computer download drivers
in your device manager do you have any with a yellow mark on them if so click on the small + which extends menu right click properties and uninstall any drivers. reboot go back to device manager or install hardware and install the driver you downloaded
they also may come with an install or setup file use this after removing old drivers
How to Install YouTube DL.py to Download YouTube Videos to my PC?
Actually, you just need the help of a YouTube Downloader. If you still need help, why not try this YouTube/Video Downloader?
Leawo YouTube Downloader acts far more than a single online video downloader to download YouTube videos and other online videos from various video sharing sites like Facebook, Dailymotion, AOL, iFilm, Myspace, Dailymotion, etc. Besides the ability to download online flash videos, this FLV downloader could also acts as video download accelerator to speed up online video downloading, video accelerator to speed up video buffering for smooth playback, video player to play back videos, and IE browser to browse online videos for free downloading. It could extract audios out of online videos, like converting YouTube video to MP3.
Hope it can be another choice for you or other users. :)
Watch online videos offline freely with Leawo YouTube Downloader
What is digital marketing?
Digital marketing, or “online marketing,” is a form of advertising that uses the internet and digital technologies to connect with customers. Digital marketing seeks to accomplish the same thing as traditional marketing except by leveraging computers, smartphones, and other digital devices rather than traditional media, such as print, radio, or television.
