20 Most Recent Monster Cable Monster Central 121161 Remote Control Questions & Answers
Battery life of four hours.
wrong site fixya does not sell products
5/3/2017 1:18:39 PM • Monster Cable... • Answered on May 03, 2017
2answers
Trying to download firmware for
Hi
You tap the F8 key repeatedly on restart, until you see the screen, use arrow keys and enter key to select the safe mode with networking .
Check this link if it helps:-
http://www.bleepingcomputer.com/virus-removal/remove-antispyware-soft
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
9/12/2011 5:33:16 PM • Monster Cable... • Answered on Sep 12, 2011
0answers
I need a replacement battery
they arent available at stores
Monster USA
Toll Free Number
1 877 800-8989
or http://www.monstercable.com/service/default.asp
12/3/2010 8:35:30 PM • Monster Cable... • Answered on Dec 03, 2010
0answers
HarmonyProcess error '800a0005'
WHEN LOGGING IN
Cause:
Comunication error with a Logitech server.
Solution:
You will need to completely exit out of the Harmony software and re-launch it. To do this:
1. Quit the Harmony software
2. For Windows base PC's, right click on the Harmony icon from the system tray and click on Exit
3. For Mac, quit the software by clicking on Logitech Harmony Remote Software menu at the top of the screen and then clicking on Quit 4. Logitech Harmony Remote Software
5. Open the Harmony Remote Software
You should now be able to login.
WHEN UPDATING
Run the Activity wizard, one at a time, for all of your Activities.
1. Launch the Logitech Harmony Remote software and login to your account
2. From the Harmony homepage, select the first Activity listed and click on the Settings button for it
3. Select Review the settings for this Activity and click on the Next button
4. Select No, I want to run the setup wizard again to change these settings and click on the Next button
5. Move through the wizard by clicking on the Next button to move to the next page, ensuring that all questions have been answered correctly. Usually a setting will be unselected, causing the error
6. Repeat for every Activity in your account, attempting to update each time to check if the error has been corrected
If you are still unable to resolve your issue, let me know
1/25/2010 9:31:47 PM • Monster Cable... • Answered on Jan 25, 2010
Can't run software to reprogram the remote. just
I need the code for oneforall remote code for a RCA F27440 so I can program my tv
1/8/2010 11:03:16 PM • Monster Cable... • Answered on Jan 08, 2010
My monster remote is not working
I have screen saver that save info and some coding underneither. I can not figure how to remove the screen so I can operate the remote. Could you help me?
11/21/2009 3:05:55 PM • Monster Cable... • Answered on Nov 21, 2009
My monster remote is dead and will not recharge.
If your warranty has expired I suggest you replace the lithium-ion battery for about $30 USD. The AV-100 takes the same battery as several logitech models, so you can pick it up from the logitech store online or other remote shop such as this.
I hope that helps.
10/26/2009 2:40:12 PM • Monster Cable... • Answered on Oct 26, 2009
The remote wont turn on/off any systems. monster
check whether the shot enta emitting light emitting control if ok then the problem is in the receiver
8/22/2009 5:40:11 PM • Monster Cable... • Answered on Aug 22, 2009
Monster power lights blinking
I noticed my 5100 LEDs flashing 80/800 for about 30 minutes, but my stereo system was operating normally. Then all by itself my 5100 returned to normal operation, correctly showing the incoming line voltage. My Monster voltage regulator, in line after the 5100, shows the input line voltage fluctuating between 116v and 117v out of 120v, relatively low. The weather here has been stormy, and there may be abnormal voltages in the power supply to my condominium.
10/13/2023 3:56:25 PM • Televison &... • Answered on Oct 13, 2023
Harman kardon avr 300 rds
check on ebay.com :)
1/26/2014 10:40:18 AM • Monster Cable... • Answered on Jan 26, 2014
2012 troybiilt super pony transmission axel is trying to slide out how to fix it
The axles may have substantial amount of in/out play, 1/4 inch or more. Does the axle in question actually drive the wheel or does it freewheel?
It's a typical differential so if you get both wheels off the ground and spin one wheel, the other wheel should rotate in the opposite direction.
The axles are retained by the differential assembly (inside transmission) so if the axle is truly falling out, to fix it will require transmission be removed and opened. Probably not an economical repair unless you can DYI or replace with good used unit.
4/19/2024 9:41:16 PM • Televison &... • Answered 6 hours ago
What is the sky remote code for a cello model c20234f-led ?
Turn on your Sky Box and TV. On your Sky Remote, press the TV button. Simultaneously press the Select and Red buttons until the red LED on your remote blinks twice. Enter one of the following 3-digit remote codes for Sky TV: 2274 2169 1874 1798 1872 1873 The light on the remote should flash twice. If it blinks only once, repeat the steps with the next code. Press the Standby button on your remote. If your television turns off, press the Select button to save the setting. Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful. Remember that there are multiple versions of Sky Remote Controls available, so ensure you have the most recent version. If you encounter any issues with the 3-digit codes, you can also try using a 4-digit code. Here's how: Repeat steps 1 to 3. Enter the 4-digit Sky remote code for your TV brand. Press the Standby button. If your TV turns off, press Select to save your settings. Check if the TV Guide displays successfully on the screen. Sky TV Remote Control Codes
4/19/2024 8:32:21 PM • Televison &... • Answered 7 hours ago
2answers
Harwa 32 Inch Led Television. How do I update my software on my Harwa 32 inch as my apps show it needs an update.
To update the software on your Harwa 32-inch TV, follow these steps: Check Other Solutions First: Before proceeding with a firmware update, ensure that you've tried other troubleshooting solutions. Sometimes issues can be resolved without updating the firmware. Gather Necessary Items: You'll need the following: A computer with an available USB port. A high-speed internet connection. A USB flash drive. Find Your TV Model Information: On your TV, navigate to the Help menu and select System Info. Write down your TV's model, revision, and firmware information. Download the Firmware Update: On your computer, visit the Insignia Products website at www.insigniaproducts.com. Click on Support & Service. Enter either NS-19D220NA16 or NS-19D220MX16 in the search box under Manual, Firmware, Drivers & Product Information. Follow the Firmware Installation Guide: Download the firmware update from the Insignia website. Copy the firmware file to a USB flash drive. Install the Update on Your TV: Plug the USB flash drive into the USB port on the side of your TV. Press the MENU button on your remote. Navigate to HELP and press ENTER. Highlight Update Firmware and press ENTER. Confirm that you want to update the TV firmware by selecting OK. Your TV will display a status screen while installing the update. Do not turn off your TV during this process. Once the update is complete, unplug the USB flash drive and press ENTER. Your TV will turn off and then back on to finalize the update. Rescan for Channels (if needed): If your channel list has been deleted, you'll need to scan for channels again. Refer to your TV's manual for instructions on how to do this. Remember: If you encounter a message saying the firmware file is incorrect, ensure you've downloaded the correct file for your specific model. If the update fails or your TV screen remains blank with a blinking red then blue power LED, turn off your TV, turn it back on, and run the upgrade again.
4/19/2024 7:23:41 PM • Televison &... • Answered 9 hours ago
Need a new remote control for iheater ih1500--how much does it cost and can you ship it to me? model IH1500 Serial IHA080939250
Sorry, we do not supply anything. I would aproach the supplier or manufacture for advice and spares availability.
4/19/2024 3:13:01 PM • Televison &... • Answered 13 hours ago
Sorry, but we do not supply parts. This is a website for advice on repairing items. You could try contacting the store you bought it from or contacting iheater directly.
4/19/2024 3:12:50 PM • Televison &... • Answered 13 hours ago
Where is the Google on the Matertech?
It appears that there could be miscommunication. As of my previous update in January 2022, Matertech doesn't seem to be a commonly known term or corporation. On the other hand, if you're talking about "Google," it's a well-known worldwide technological corporation that specializes in internet-related services and goods, such as search engines, cloud computing, online advertising technologies, software, and hardware. Google's official website or an internet search utilizing one of the search engines like Google itself are usually the easiest ways to get information about Google. If "Matertech" relates to a particular thing or idea, further information could be helpful in order to provide a more precise answer.
4/16/2024 4:37:21 PM • Televison &... • Answered 3 days ago
2answers
Changhong tv
Refer its user manual for details.
4/16/2024 3:46:48 PM • Televison &... • Answered 3 days ago
Televison & Video Logo
16 questions posted
Top Monster Cable Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Monster Cable Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Monster Cable Televison & Video
Most Popular Question
need replacement battery
  • Televison & Video
