20 Most Recent Seagate 80GB 7200 rpm SATA/150 8MB Serial ATA HD REFURBISHED p/n ST380817AS (ST380817ASR) Hard Drive Questions & Answers
4answers
How can i installed driver of sata hdd for linux red hat
if you are installing red hat 8 and higher there is no need to install extra driver because linux is the only operating system which will install everything including drivers, office suite,programming tools etc .... as far as my suggestion dnt install old versions of linux instead install new version ... there are many linux available
ex: fedora core 4,5,6 ,knoppix live cd linux ( which boots linux from cd no need install it) ,ubuntu,red hat,mandrake,suse ....
you can download it from net 4 free as linux is open source 4 all ...
be careful while installing linux especially during partitioning..... if u make a mistake you will lose all datas
3/16/2011 12:47:32 PM • Seagate 80GB... • Answered on Mar 16, 2011
My external 80 gig seagate drive wont let me get
try to connect it to a different computer if it does the same thing than the read/write head is damaged.
3/3/2011 3:45:44 PM • Seagate 80GB... • Answered on Mar 03, 2011
Im trying to install red
RH 9 is an old distribution. It simply may not be able to recognize SATA drives.
(Red Hat Linux 9, the final release, hit its official end-of-life on 2004-04-30 - Wikipedia).
If you are looking for a desktop solution, you would be better off looking at any one of these newer (and supported) distributions.
Ubuntu
http://www.ubuntu.com/
Fedora Project
http://fedoraproject.org/
OpenSUSE
http://www.opensuse.org/en/
I'm not endorsing any single one. Each has it's advantages. Plus there are others besides these.
2/25/2011 7:47:02 PM • Seagate 80GB... • Answered on Feb 25, 2011
I have a 250gb seagate sata but when i put my 80gb
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
2/11/2011 4:46:40 PM • Seagate 80GB... • Answered on Feb 11, 2011
2answers
Hard drive is not getting
try these 1-Check Here for common problems 2-Find Linux drivers for the SATA drive
1/26/2011 12:35:13 PM • Seagate 80GB... • Answered on Jan 26, 2011
My Hdd Has Been Not
Sounds like your drive needs to be formatted, click the start icon in your taskbar then right click "computer" and select "manage" this will open the "computer managment" window from the list select "disk managment" and your drive should be visible in the lower list on the right. Right click and select format from the list. Hope this helps
8/26/2010 5:10:21 AM • Seagate 80GB... • Answered on Aug 26, 2010
2answers
How to find my hdd warranty??
If you want to know the warranty of your hdd then click the below link and fill the details and check your warranty
http://support.seagate.com/customer/warranty_validation.jsp?form=0
How To Find Model and Serial Numbers
If your drive is connected to your computer: Seagate has created a very simple tool that will tell you the serial number and the model number of any and all Seagate and Maxtor-brand drives connected in or to your computer. Use the DriveDetect.exe method to find both numbers.
You can also use SeaTools to display each number.
(See below if you have a Mac computer.)
If your drive is not connected to your computer: See the flash-based Serial Number locator tool to find your serial number and model number (and/or occasionally the serial number and the part number) on the drive label.
Please rate me if this solution works for you
Thanks......Have a great time
8/11/2010 6:57:07 AM • Seagate 80GB... • Answered on Aug 11, 2010
Im trying to install red hat linux enterprise 9
Change the SATA mode in bios or use Cent-Os which is the same as Red Hat or try Fedora
Please rate my help++++Thanks for using FIXYA
5/15/2010 5:17:23 AM • Seagate 80GB... • Answered on May 15, 2010
I have installed VMware server and when i start
Try changing the SCSI adapter type opposite to what it is set to now, BusLogic or LSILogic.
3/24/2009 5:26:32 PM • Seagate 80GB... • Answered on Mar 24, 2009
Im trying to install red hat linux enterprise 4
Use a boot partition manager to create a new partition for the operating system. A popular one is Gparted - http://gparted.sourceforge.net/livecd.php
You can use it from a CD, a USB stick, or a PXE server. One of the easiest tools around.
3/1/2009 8:22:17 AM • Seagate 80GB... • Answered on Mar 01, 2009
HDD PROBLEM
HI,
The first thing is to do a disk cleanup.Go to START>PRROGRAMS>ACESORIES>SYSTEM TOOLS>DISK CLEANUP. Make sure you also clean all the system restore files.If you've taken a backup of your PC and you want to keep it then just ignore that part or else just go to the more options tab and select clean up under the system restore option in the disk cleanup.
If this doesnot fix the problem then:
there is a temporary file somewhere inside in the c-drive which is growing and eating up all your space. CLICK HERE to download the jam software.The run a scan with it it will tell which file is taking more space.Then just brows that file and delete it.
Goodluck..
5/10/2008 11:42:46 PM • Seagate 80GB... • Answered on May 10, 2008
3answers
Bad sectors and fails under minor load
No it's not repairable. Copy any data you want from it to another drive, cd, dvd, etc. Go to www.seagate.com and fill out a warranty RMA form. If it's warranty you'll get a new one from Seagate
2/18/2008 1:09:50 PM • Seagate 80GB... • Answered on Feb 18, 2008
2answers
SATA 80GB Seagate HDD
When your 80GB SATA Seagate HDD complains of bad sectors while booting, this is a sign of a failing hard drive. Today's hard drives will actually self-correct a certain amount of bad sectors before you get any kind of error message. If you are getting "bad sector" errors, this is because the drive has so many problems that it can no longer self-repair. You asked if this may have happened because you have formatted the drive many times. No, bad sectors was not caused by formatting. Your drive did not become "dead slow" because of the formatting. It became slow because your cpu now has to do much more processing to "work around" the bad sectors on the drive. You also asked if you could recover your hard drive to normal state. Please understand that once a drive shows bad sectors, it will not be long before the drive fails completely, at which point you will no longer be able to access anything at all on the drive. No, this drive cannot be recovered. Instead, you should save all the data you can from this drive, and you should do this as soon as possible, before it fails altogether.
1/8/2008 8:54:11 AM • Seagate 80GB... • Answered on Jan 08, 2008
How to delete backup on my seagate backup plus slim
Detailed steps to manage backup disk space
To delete old backups on Windows 7/8/10 using AOMEI Backupper, you need to set up Backup Scheme during the process of creating a backup. When your backup versions exceed the number of backup images files, AOMEI Backupper will delete older backup automatically. Step 1: Connect your Seagate Backup Plus drive or Central hard drive to the computer and make sure it can be detected by your computer. Step 2: Download AOMEI Backupper Professional, install and launch it. Step 3: Click Backup and File Backup subsequently Step 4: Choose the files and folders you want to backup and pitch on a path for it. Then, Click Schedule option and select Schedule Settingsfrom the following window. Step 5: Click Scheme option, tick Enable Disk Space Management and select whatever Scheme you need from the drop-down menu. Then, back to the main page of File Backup and click Start Backup. After that, your older backup will be deleted automatically when your file backups exceed the versions of backup image files.
2/26/2024 7:21:41 AM • Seagate... • Answered on Feb 26, 2024
Ive got a 8tb seagate its got a blinking blue light and wont connect to my Pc? Any help?
Did you initialize it?
7/3/2023 8:38:03 AM • Seagate... • Answered on Jul 03, 2023
Seagate Portable Hard drive 4TB, part number 2N1AP6-500
Hi, Please put your computer into safe mode before attempting to connect to the hard drive again. Safe mode turns some feature off when activated so whatever program is forcing the shutdown might have be paused when connecting to the external hard drive. Also, try connecting the hard drive to a non-laptop intermediary device and then connecting that device to your computer and attempting to access the hard drive folder within the intermediary drive. Thank you.
11/11/2022 2:11:28 AM • Seagate... • Answered on Nov 11, 2022
2answers
How to recover data from a dead Seagate external hard drive on my Computer?
Should be careful with the data file deposited on the Seagate external hard drive. your Seagate external hard drive might be dead or corrupted. In this situation, you might need to rely on data recovery software to get back data and files on the dead Seagate external hard drive. So you can rely on data recovery software to get back lost data and files when the Seagate external hard drive is dead and inaccessible. Data recovery hong kong technician provide the Ontrack EasyRecovery data recovery services are able to recover data and files from accidentally formatting, corruption, virus attack, dead, system crash under different situations Seagate external hard drive on Windows Computer. This data recovery software allows you to deep scan the dead Seagate external hard drive so as to find out almost all lost files with original quality in a short time. You can also rely on this software to recover files from dead/damaged Seagate external hard drive. The software supports to get more recover: Seagate External hard drive, data file, documents, PDF, Excel, photos, music, and videos any HFS, HFS, FAT, ExFAT, and NTFS format based data and file and more. It will recover data and file from all external storage devices that can be recognized by your Windows PC Computer/Laptop. Hope this helps you get to recover all your lost data and files from your dead Seagate External hard drive.
10/8/2021 1:02:33 PM • Seagate... • Answered on Oct 08, 2021
What enclosure is compatible with a Seagate Barracuda 7200.7 SATA Drive?
TRY LOOKING FOR TIGERDIRECT .COM THEY SELL STUFF FOR COMPUTERS
10/3/2021 8:21:41 PM • Seagate... • Answered on Oct 03, 2021
Seagate 80GB 7200 rpm SATA/150 8MB Serial ATA HD REFURBISHED p/n ST380817AS (ST380817ASR) Hard Drive Logo
Popular Tags
16 questions posted
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Seagate Computers & Internet
Most Popular Question
find hdd warranty
  • Computers & Internet
