20 Most Recent
Brother PS-1250 Pacesetter Questions & Answers
Servicing a PS 1250 sewing machine
It's difficult to tell, but it looks like your machine is computerized. Most computerized machines require very little, if any, oiling. The only oiling recommendation I've seen for some machines is a drop on the hook. Follow the instructions in the manual and take your machine for annual service. Applying oil anywhere else could damage the computerized parts.
How do i do a screen clabration on a brother
try this
While pressing the start/stop, reverse stitch and needle position buttons, turn on the power to display the screen
for the touch panel adjustment mode.
2. While pressing the start/stop button, touch the touch panel at the positions marked by crosses (+) in order from 1 to
5.
(When touching the touch panel, use an object with a rounded tip such as a pencil or matchstick. Never use a
hard or sharp-pointed object.)
If the buzzer sounds once when cross number 5 is touched, the adjustment has been made correctly.
If the buzzer sounds twice when cross number 5 is touched, an error has occurred. In this case, touch the
crosses on the touch panel again in order from 1 to 5.
Never press the thread cutter button during this time. (Doing so may cause a malfunction.)
3. Turn the power off, then on again and check that the screen display and the touch panel positions are aligned
How do i wind bobbin. help!
My method may not be the best but it does work. If you have a plastic or metal bobbin with a hole in it thread the thread through the hole where you would have a 1/2 inch piece hanging out as you put it on the bobbin winder. Hold it tight engage the pedal and hold it the whole time you are winding your bobbin. Hope this helps.
User manual
here is a link for the manual, it's not free, you can try contacting brother customer service and see if they have a free one, but I couldn't find one for free
How do I oil my machine?
contact brother customer service about oiling the machinesome sewing machine are self oiling from the factory, you needto ask brother customer service if your machine is oiled by you or self oiling.
