20 Most Recent
Advance Keywind Alarm Clock Questions & Answers
Advance alarm clock manual
Yes, you can adjust the LED display brightness on the Advance Model 3138 alarm clock. To adjust the brightness, follow these steps:
- Press and hold the "SNOOZE/DIM" button for 2 seconds. The current brightness level will appear on the display.
- Press the "SNOOZE/DIM" button repeatedly to cycle through the available brightness levels.
- Once you have selected the desired brightness level, wait for a few seconds for the clock to automatically save your selection.
Note that the brightness levels are labeled as "HI," "MED," and "LO" on the clock. If you want to turn off the display entirely, you can press the "SNOOZE/DIM" button once more after selecting the "LO" brightness level.
Creative t20 left speaker working intermittently
This unit is a powered speaker and what you are describing sounds like a bad connection or component in the amp. some parts can get hot and lose the connection on the amp board or the power board. It could also be a failed component
How do I set the time an alarm on this Advance Digital alarm clock model 4073
Press and release Time. Press and release each number of the time: if the time is less than 10:00, start with a 0, otherwise start with 1. Press and release the PM button if it is afternoon. Press and release Enter. Press and release Alarm, then press and release Time to confirm it is set.
(Took me forever to figure this thing out)
