20 Most Recent
LG VX6000 Questions & Answers
Transfer Music, Photos
In addition to having th cable and installing the proper drivers, you also need software to transfer data between your phone and computer. For example, you can use
this software to transfer data.
8/19/2015 9:27:12 AM •
LG VX6000
Answered
on Aug 19, 2015
Lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
Not exactly a solution. I tried leaving it off overnight and tried it several times after removing and inserting the batteries. I also cleaned the contacts with contact cleaner and a Q tip. It did not fix it. But I just left it off for 2 days meaning to go to the Verizon store and get it fixed or replaced. But I turned it on now and it fixed itself! Model VX8300. Maybe the contact cleaning did it but it had to dry more. You can use a Q Tip dipped in a cup of water with a teaspoon of Mr.Clean. But then rinse it with a water wet Q tip and then dry it with a paper towel. I used contact cleaner.
6/13/2014 3:48:18 AM •
LG VX6000
Answered
on Jun 13, 2014
My cell phone is locked
You have two options
1.can call *228 and press 1 to reprogram your phone and both your general password (Phone Lock Code) and restrictions password (Service Lock Code) will be reset to their default values (the last 4 digits of your telephone number for both).
2.Go to the service provider's office ,they will provide the code for you.
Thank You
Reply
10/1/2010 6:07:35 PM •
LG VX6000
Answered
on Oct 01, 2010
Unlock LG VX6000
As you have not specified which code you need i am hereby giving how to get all of the codes:
NETWORK UNLOCK CODE:
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA mobile , you can get the network unlock code(NUC) by just contacting the current network provider customer caredepartment.It is free of cost.
Therestrictioncodecan
be got from your old service provider..This restriction code iskeptto
prevent someone who stole themobile from using it withanotherprovider...
They will have a security check done with your date of birth etc..to verify whether you are the exact owner of the phone..
After that they will provide you the restriction code to unlock it and use it with another service provider..
It is all free of cost donot pay anyone for this seeing some advertisement over internet . That is all fake ads.
The above proceudre works and you can verify that by seeing the rating of an happy customer here..
http://www.fixya.com/support/t4035818-need_unlock_nokia5130c_2_use
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If
you try pin more than few predefined no of times your phone will ask
PUK code which can also be given only by your service provider which is
specific for each and every mobile number . Do not try PUK(new pin code)
code many times or else your sim will be blocked and you will need a
new sim.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
8/9/2010 6:09:00 AM •
LG VX6000
Answered
on Aug 09, 2010
Motorola Q was in the pool for 5 seconds. The
remove your battery and keep near by warm place for 1 hrs and reinsert the battery try to switch on the phone its not working and pls charge your phone for 2hrs it will turn horn
7/5/2009 3:04:34 AM •
LG VX6000
Answered
on Jul 05, 2009
Pantech Duo dropped in Coke
AT&T isn't going to fix it.
If you recently got it I suggest you buy a warranty and wait a week and then get it fixed threw the warranty.
4/25/2009 2:45:19 PM •
LG VX6000
Answered
on Apr 25, 2009
