20 Most Recent Nokia 3220 Questions & Answers
please help my phone for some reason says phone restricted and when i press the undo butten it says enter restriction code
Nokia 3220
serial no: 352737/01/455689/90518259
south africa
Nokia 3220 | Answered on Jul 07, 2019
Default security code is - 12345
IMIE - 355006.00.193246.4
Your master code is - 1434763676
Please don't forget to rate this solution.
Nokia 3220 | Answered on May 22, 2019
look at this link
http://forums.wirelessadvisor.com/nokia/52801-unlock-code-for-nokia-3220b.html
These Nokia Unlock Codes are Generated For Nokia 3220B with IMEI: 356668004865238 (DCT 4) Locked to Provider T-Mobile in U.S.A. and will only work with this phone!
#pw+946222166474732+1#
#pw+154324073255534+2#
#pw+016363733425471+3#
#pw+299155417703167+4#
#pw+917542030577256+5#
#pw+985342603325150+6#
#pw+287495402556703+7#
Recommended CODE :#pw+287495402556703 +7#
  1. Remove SIM CARD !
  2. Type #
  3. Then press the * key 3times (you should get a "p")
  4. Then press the * key 4times (you should get a "w")
  5. Then press the * key 2times (you should get a "+")
  6. Then enter: 287495402556703
  7. Then press the * key 2times(you should get a "+")
  8. Then enter: 7
  9. Enter: #
IF UNLOCK SUCCEEDS YOU SHOULD SEE RESTRICTION REMOVED ON SCREEN, YOUR PHONE IS NOW UNLOCKED!
POSSIBLE ERROR MESSAGES:
  • If you get CANNOT UNDO RESTRICTION your phone cannot be unlocked remotely and you need to take your phone to a shop!
  • If you get CODE ERROR the above codes do not work for your phone DO NOT ATTEMPT TO ENTER THE SAME CODE AGAIN
    Repeat above instructions, but with the numbers from code 1 (#pw+946222166474732+1#) if code that does not unlock your phone STOP! . You need to take your phone to a shop to have it unlocked
Nokia 3220 | Answered on Apr 18, 2019
It's on vibrate.
Nokia 3220 | Answered on Oct 16, 2016
That depends on whether you saved your media to the SD card or just to the phone's memory. If it went to the SD card then you can recover it all with an external card reader. Otherwise the data may be lost
Nokia 3220 | Answered on Oct 05, 2014
Hi. You can get the restriction code for a Nokia 3220 from
MobileUnlockSolutions.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia 3220 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3220.
3 - Compose #pw+CODE+1#.
4 - The Nokia 3220 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 3220 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
Nokia 3220 | Answered on Jul 08, 2014
imei:351860018288243 model 3220 rh-37
provider: smart
philippines
can anyone help me with my restriction problem?
Nokia 3220 | Answered on Jun 23, 2014
is that symbian os?.if symbian...pres call button,*&3key together..it will format your fone hardly..if not symbian...contact a mobile store and software it
Nokia 3220 | Answered on May 26, 2014
Your provider should have that information or be able to give you a code to open this.
Nokia 3220 | Answered on May 25, 2014
You can use Master Reset Code to Reset your mobile.
The master reset for your Nokia 3220 is 3441544421 .
I generated the code for your Phone using Unlock-Free.com
Nokia 3220 | Answered on May 24, 2014
gan 3220 enter restriction code
Nokia 3220 | Answered on Dec 05, 2013
You can get restriction code for your Nokia 3220 mobile phone from Unlocking4u.com at reasonable price.
Nokia 3220 | Answered on Nov 26, 2013
Give that password that u have set and it will get unlock
Nokia 3220 | Answered on Nov 18, 2013
398 questions posted
Popular Products
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
View Most Popular
Nokia Cell Phones
  • Nokia Cell Phones
Most Popular Question
ringer not working
  • Cell Phones
