20 Most Recent
Nokia 3590 Questions & Answers
How do i break restriktec code to my nokia 3590
HI is your Nokia 3590 mobile is asking for restriction code once you insert your sim in it then it mean your phone is locked to some other network provider due to this it wont accept any other GSM sim until you unlock it .You can easily unlock your phone using sites like
Unlocking4U.com here they are rendering network unlock code for all mobile models at reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone then freely use it with any GSM sim ...
Nokia 3590
Answered
on Sep 16, 2014
Enter restriction code
If you mobile displays Restriction Code, then it is locked with some network and requires a code to be entered, to allow your mobile to use any network. Restriction code for your Nokia 3590 model mobile can be got at
Prounlocking.com , which gives easy instructions to unlock your mobile........
Nokia 3590
Answered
on Jan 02, 2012
My nokia keeps saying stop restriction code can
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
If you want to use a network other than the one provided
with the phone, you need to enter the restriction code. When the restriction
code is entered in the mobile, your phone can be used with any network.
Restriction codes are available at www.mobileunlockingsolutions.com. Submit your mobile
details there to get the code.
Nokia 3590
Answered
on Oct 20, 2010
Can you provide me with phone unlock code for
ok what u have to do in this case u need to remove the sim and switch on the phone and then press
# & * key type #pw+486367301405173+7# ,after this your phone would say restriction removed then put ur sim
inside yr phone would work for sure if doesnt work let me know .
Nokia 3590
Answered
on Jun 25, 2010
Unlocking Problem Nokia 6500s
your IMEI: 352027021230088
mastercode:
563773451x
The mastercode can be entered instead of standard security code.
please do not forget to rate this solution if it works.
and Thanks for using FixYa.
Nokia 3590
Answered
on Mar 20, 2010
Hi can you please give
Visit www.unlock-free.com/nokia or www.unlock.nokiafree.org
Follow steps and instruction and your problem would be resolved.
I hope it works for you, because is as worked for me several times.
I wish you the best.
Nokia 3590
Answered
on Dec 30, 2009
Code restriction nokian 6500s
HI
A numeric code (password) that prevents a user from accessing certain technical settings of a phone. It is specifically designed to prevent a phone from being reprogrammed to work with a different carrier (service provider).
This is what is usually meant when a phone is referred to as "locked". There are also "unlocked" phones that can be reprogrammed to work with a different carrier.
The reason for this system is the way phones are often sold. Many phones are sold below cost, (at a loss to the carrier,) with the expectation that the money will be recouped in the cost of the monthly service plan. The up-front loss that is later recouped is called a Subsidy.
For this to work financially for the carrier, the user must not buy the phone and then use it with a different carrier. The MSL makes that nearly impossible.
Unlocked phones are ususally much more expensive than locked phones, because there is no subsidy to offset the cost.
You should ask the operator for the subsidy code
Nokia 3590
Answered
on Sep 04, 2009
