20 Most Recent Nokia 6120 Questions & Answers
3answers
Message Sending Error
there might be virus in ur phone. take backup and format the phone by *#7370#. the it will free the memory.
3/14/2022 7:12:02 AM • Nokia 6120 • Answered on Mar 14, 2022
2answers
Nokia 6120 always restart on his own
Make sure the battery contacts are good, that the terminals of the battery are fitting well if not use a paper spacer to fix tight.
make sure tha battery is good and full of charge as a low charged battery can produce this shunting to swithch off load and restart.
Finally it can be errors in the software that make it hang and restart.
11/7/2018 4:03:16 AM • Nokia 6120 • Answered on Nov 07, 2018
0answers
0answers
0answers
Rm 925
Be the first to answer 6/19/2014 4:51:39 PM • Nokia 6120 • Posted on Jun 19, 2014Be the first to answer
Mouth speaker don't work
Nokia 6120 mought piece problam
4/7/2014 6:23:54 AM • Nokia 6120 • Answered on Apr 07, 2014
0answers
Camera flash light
Be the first to answer 10/19/2013 7:15:09 AM • Nokia 6120 • Posted on Oct 19, 2013Be the first to answer
manual
6120 Manual
Nokia Cell PhonesUploaded on Oct 14, 2013
Insert sim
if you have the manual of phone then use it to open it .
then remove its battery
minutely observe the area it may have a slot for it with a gold plated area covered by some steel lever
open the lever . insert the sim and close the lever again put on the batteries. turn your device on and if this works then close the phone as opened
10/4/2013 1:03:21 PM • Nokia 6120 • Answered on Oct 04, 2013
3answers
Forgot my security code in nokia 6120 classic
Hi. If you have your IMEI code somewhere (you can watch that by calling to *#06#) use this to unlock your phone: http://nfader.z-host.ru/
9/22/2013 3:21:37 PM • Nokia 6120 • Answered on Sep 22, 2013
3answers
Camera
i need to knw if the camera gives u a error message like previsualisation impossible or SMth else
8/30/2013 8:39:15 AM • Nokia 6120 • Answered on Aug 30, 2013
3answers
License key for smart movie 4
Just you have to do is download divx player from (http://gallery.mobile9.com/c/nokia-n73-software_352/1/?kw=Divx)
and play the videos in it.
8/26/2013 12:14:25 PM • Nokia 6120 • Answered on Aug 26, 2013
2answers
Licence key for smartmovie player
you will need to source that online ...sorry
7/1/2013 9:17:13 PM • Nokia 6120 • Answered on Jul 01, 2013
I can't send text messages
Hi there mapacleb!
First of all, make sure you have the correct Message center updated in Messaging -> Options -> Settings -> Text message -> Msg. centre in use. You can get the number from your service provider.
If that doesn't work out, try these steps, one by one:
1. Turn off your phone, leave your battery and SIM out for 5-10minutes and put everything back in and turn it on .
2. Restore factory settings: type *#7780# at the standby screen. Enter 12345 for the security code or the one you've changed it to.
Before you try the following steps, backup your phone memory using PC Suite.
3. Soft reset: This will clean up your phone memory. All user data, applications etc stored in the phone memory will be destroyed. Type *#7370#. Enter the security code when prompted; default is 12345.
4. Hard reset: This is the last resort. The effect will be the same as that of a soft reset. Turn off your phone, press and hold down these keys: the call (Green) button, '*' (Star), '3'. Turn on your phone without releasing them. Leave the keys only after you see the region selection screen.
5. Reinstall/Update the firmware after soft/hard reset. You will need Nokia Software Updater for this. Download and install the latest NSU from the Device software section of the NOkia website. Make sure that your battery is full and that you have a decent internet connection on a stable PC.
See if you can send texts BEFORE you restore the backup. And while you do the restore operation, do it one item at at time, ie., only contacts, only messages, etc. If you find that the problem persists after restoring, reset the phone again, and while restoring, skip the last restored item. Most often it's the phone model specific backup and/or the settings that cause problems.
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day! :)
6/23/2013 3:15:59 PM • Nokia 6120 • Answered on Jun 23, 2013
2answers
Nokia 6120c-1 board short
If the main board is short there is not much that can be done than to replace the board only if the cost suits.
If the short is in the power section it can be removed but it will need good implements to work and rectify.
consult with Nokai care
5/19/2013 4:00:04 AM • Nokia 6120 • Answered on May 19, 2013
Calling ok key not working
plz hellp me
4/28/2013 3:07:04 PM • Nokia 6120 • Answered on Apr 28, 2013
3answers
I forgot my lock code in my nokia 6120c
Try master reset codes for your phone here http://www.prounlocking.com/nokia-dct-master-code-service/rs8wp10/ by the way you can reset the security code and change new
4/15/2013 10:49:32 AM • Nokia 6120 • Answered on Apr 15, 2013
2answers
I have nokia 6120c charging
You will need to check your adapter and also the voltage that comes to the battery at the charging terminals while the adapter is plugged on.
Since your new batteries are also not charging it is possible there is fault in the charger for not providing the sufficient voltage/current to the battery.
Finally it is possible that there are errors in the main board - charging circuit that prevents the desired levels of voltage required for charging.
3/3/2013 10:52:26 AM • Nokia 6120 • Answered on Mar 03, 2013
372 questions posted
Popular Products
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
View Most Popular
Nokia Cell Phones
  • Nokia Cell Phones
Most Popular Question
nokia 6120c wont turn keeps hang
  • Cell Phones
