20 Most Recent
Nokia 6610 Questions & Answers
Bsnl sim card rejected
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
3/24/2022 10:37:42 AM •
Nokia 6610
Answered
on Mar 24, 2022
NO NETWORK
Check the SIM on another phone and if this works then the fault seems related to a faulty motherboard.
You can clean the SIM contact pins, also if you are equipped remove the motherboard , check for dirt or moisture , clean and reset . If the fauIt stays then it seems that the motherboard is a suspect. need to take consensus and estimate before you spend any money on a trial basis.
9/23/2011 5:39:00 AM •
Nokia 6610
Answered
on Sep 23, 2011
