20 Most Recent Hotpoint WMA54 Front Load Washer Questions & Answers
I HAVE BROKEN THE HINGE ON MY WASHING MACHENE DOOR
Go to YouTube find how to open your washer. There is a parts diagram inside with all parts and part numbers listed.
1/19/2018 2:00:08 PM • Hotpoint WMA54... • Answered on Jan 19, 2018
2answers
A strange smell is coming from the drum
go on espares and buy the limescale and detergent remover this should clean the machine out
8/5/2014 2:56:31 PM • Hotpoint WMA54... • Answered on Aug 05, 2014
How do you take out the filter on a AEG LAVAMAT, 12843 VIT.
HI,SOME TIMES A COIN OR HAIR GRIP CAN JAM UP THE MAIN PART OF THE FILTER,IF YOU CAN IS TO REMOVE THE WHOLE PUMP TO CLEAN IT OUT,POWER OFF BEFORE YOU DO IT ,THANKS.
7/4/2014 9:16:29 AM • Hotpoint WMA54... • Answered on Jul 04, 2014
Smelly Washing Machine
There is a product called washer magik and is designed specifically for the problem of smell. The rubber bellows, or gasket, is notorious for causing that to happen. If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
7/2/2014 7:33:47 PM • Hotpoint WMA54... • Answered on Jul 02, 2014
Filter
These model appliances have the filter as part of the sump assembly, you will need to unplug the appliance, on the back of the appliance is an access panel held on by screws, remove this and the pump assembly is on the bottom right hand side and the sump will be connected to the bottom of the drum assembly by a hose clip, inside this black pipe is the filter
4/12/2014 9:41:21 PM • Hotpoint WMA54... • Answered on Apr 12, 2014
Drum not going round at all
can i Have the complate Model Number so i can get you back up and running?
2/9/2014 6:31:47 PM • Hotpoint WMA54... • Answered on Feb 09, 2014
0answers
2answers
Locating the filter on the Hotpoint WMA54 front load washer
To check and clean the filter, you need to remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction or blockage here and in the pump as well.
Hope this helps to solve your question.
Please leave feedback.
Thanks.
9/26/2013 9:54:19 PM • Hotpoint WMA54... • Answered on Sep 26, 2013
2answers
Fabric conditioner not going into machine
Hotpoint WMA54 Front Load WasherFabric conditionernot gong to machine, This video will show you how to keep yoursoap draw clear and how to service the partsPlease remember to subscribe to our YouTube channel for all appliance tutorialsa 4 THUMBS rating is appreciated for answering your FREE question..
8/6/2013 3:44:30 PM • Hotpoint WMA54... • Answered on Aug 06, 2013
2answers
I have cleaned the filter but my machine is still
Not draining clean /filter located in sump hose ...Water not entering could be faulty solonoid valve...
8/6/2013 3:42:44 PM • Hotpoint WMA54... • Answered on Aug 06, 2013
2answers
No fabric softener being taken from the draw of
No fabric softener being taken from the draw of washing machine This video will show you how to keep your soap draw clear and how to service the parts Please remember to subscribe to our YouTube channel for all appliance tutorials a 4 THUMBS rating is appreciated for answering your FREE question.
8/2/2013 10:03:22 AM • Hotpoint WMA54... • Answered on Aug 02, 2013
Door not locking properly
what is your model number is then we can get started then okay
2/4/2013 5:25:53 PM • Hotpoint WMA54... • Answered on Feb 04, 2013
Wm54 door locking light wont come on
IF the machine starts it is related only to a failure of the light, the connection or the wiring. If not there is fault in the main circuit unit of the controller.
12/31/2012 8:08:07 AM • Hotpoint WMA54... • Answered on Dec 31, 2012
My hotpoint WMA54 wont spin
Yes your machine will not spin if the water cannot drain... I do not have the machine in front of me but I would presume to think that you have a blockage in the water pump (or drain pump) There is a normally a small pvc or plastic filter just before the pump and this would stop most big things entering the pump.. if not there could be a coin or button stuck in your pumps impeller. Unfortunately if you are not technically inclined you will find it hard to access and open the pump otherwise just open the back plate on the machine (after removing the power socket from the wall) the pump is located at the bottom left and fairly easy to remove and open the plastic casing. If this does not solve your problem please give more info........
12/2/2012 9:48:56 AM • Hotpoint WMA54... • Answered on Dec 02, 2012
Aquarius wma54 front lights flashing
Hi Gary from retired Englishman in SW France,
As you do not say which lights and at what rate they flash I am having to guess ;-0)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter- so many 'faults' are caused by blocked filters.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
10/4/2011 7:16:55 PM • Hotpoint WMA54... • Answered on Oct 04, 2011
Even after replacing the door
(you may have already carried out some of this but.!)
Bad odours could be coming from a few places.
  1. the plumbing u-bend of the washer's room or
  2. the fact that there is 'foul' water being left in the drum.
  3. No washes at 90 degree+ !
I would suggest checking the plumbing u-bend for trouble first, then following the notes on checking and cleaning the drain filter and the drain pump to ensure there is nothing 'obnoxious' hanging around the two of them! Finally run the occasional 90+ wash to kill bacteria.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
Thanks and good luck,
John C
8/19/2011 2:50:56 PM • Hotpoint WMA54... • Answered on Aug 19, 2011
Noisy bearing,how do i get covers off?
give Garees. vote it
6/29/2011 5:35:10 PM • Hotpoint WMA54... • Answered on Jun 29, 2011
3answers
Can bearings be removed without removing the drum
sorry no its a big job but here goes isolate from electric and power remove lid and rear bottom cover.
remove soap drawer and remove screws you can see behind it then remove fascia, then undo the door seal and plinth cover ,then remove front panel.
then remove dispensor hose from tub, go to the back remove sump hose and motor and wiring to element then remove top front sub frame and undo the top and bottom weights then remove the pins that hold the suspension legs to the tub lift off the springs and the tub is free.
Then split the tub knock out the old replace with new that is assuming you dont damage the shaft of the drum support whilst removing il then do it all in reverse this normally takes me 2 hours it might take you 2 days but hey lifes full of challenges good luck
6/12/2011 9:18:12 AM • Hotpoint WMA54... • Answered on Jun 12, 2011
Hotpoint WMA54 Front Load Washer Logo
90 questions posted
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
out filter aeg lavamat 12843 vit
  • Washing Machines
