20 Most Recent
Toshiba Satellite 15" Flat Panel LCD Monitor Questions & Answers
Dim backlight
you need to contact the manufacturer and ask to replace the backlight...
3/3/2016 8:47:57 PM •
Toshiba...
Answered
on Mar 03, 2016
No sound after Win XP Sp3 upgrade
Hi there, You need to download the sound drivers from the website of computer manufacturer and install it again if not try running Windows updates as even that will download and install it.
Hope this helps you to solve the issue. Please do vote or provide feedback on this solution as it will be appreciated.
Thank you
Gowtam R
6/24/2011 3:05:59 PM •
Toshiba...
Answered
on Jun 24, 2011
I have a Toshiba 1415 S173 laptop I'm working on
Hi
Once before I had a similar Toshiba come into the shop. Try turning the unit on without the battery installed and on the good Toshiba charger. The computer batteries have a minimal current level and once power has gone below this level they will cause all kinds of problems. If the Toshiba now works, you're home free - just replace the battery. If it doesn't work then it will have to see a reputable repair person who can troubleshoot chip issues. I've seen these clone power supplies do all kinds of things to computers.
3/14/2010 4:34:38 PM •
Toshiba...
Answered
on Mar 14, 2010
Toshiba Satellite 1415-s173
Hold down the Esc key when you turn on the system. Assuming your Esc key works, that'll trigger a "Hit F1 to continue.." message and take you into the BIOS.
3/11/2010 3:57:39 PM •
Toshiba...
Answered
on Mar 11, 2010
My back light on toshiba satellite 1415-s173 laptop
Replacing a backlight is better left to the experts of experts - it is very, very, very specialized. On these models, a dim screen can also be a dead inverter - I'd try replacing that first. If replacing the inverter doesn't solve it, then just replace the screen. Don't even think about replacing the tube yourself.
3/11/2010 3:55:46 PM •
Toshiba...
Answered
on Mar 11, 2010
Toshiba Satellite no wireless and want it
Your 1415 has a mini-PC card slot for an internal WiFi card. Bottom, right hand side, in the back. Buy a mini-PCI WiFi card, click it in, connect the antennas, and you're good to go.
If you dunno which card to get, this will always work: model MPC13A-20/R. Around $10 on ebay.
Of course, USB will always work but it sticks out like a sore thumb and it's cumbersome!
3/11/2010 3:51:55 PM •
Toshiba...
Answered
on Mar 11, 2010
Need to replace keyboard
The plastic strip above the keyboard - you need to remove it (start by using a small, flat screwdriver and using the Windows key as leverage). After that, it's three screws (L, middle, R), then set it upside down over the touchpad, and disconnect the cable by lifting the connectors up.
That oughta do it!
3/11/2010 3:48:01 PM •
Toshiba...
Answered
on Mar 11, 2010
Bios locked, can it be unlocked
wow... are you serious... u expect us to believe that.
''duh, a cat ran across my keyboard at the exact moment that I was trying to update my BIOS password, and she magically hit the ENTER key after pressing random keys. darn cat"....
you could try taking out your CMOS battery, that may reset the password.. i still don't believe you though.
11/16/2009 4:05:24 AM •
Toshiba...
Answered
on Nov 16, 2009
