20 Most Recent HP Compaq FP5315 15" LCD Monitor Questions & Answers
yeah replace the caps and sometimes the 7.5v zener diode burns up too. I have been replacing the surface mount ones with just a regular through diode
HP Compaq FP5315... | Answered on Nov 27, 2015
Reinstall your speaker drivers, and check if the speaker is connected to the motherboard correctly.
HP Compaq FP5315... | Answered on Nov 30, 2013
It's your video card! No Doubt! that happened to mine once and my friends and it was the same thing!
HP Compaq FP5315... | Answered on Oct 11, 2013
Clean them with microfiber cloths easily purchased anywhere.
HP Compaq FP5315... | Answered on Sep 09, 2013
you can try to solve this problem eith you're graphic driver program like nvidia control panel. i resolve this messing with "adjust desktop size and position". i hope this help!
HP Compaq FP5315... | Answered on Feb 10, 2012
Adjust all functions by using front pannel switches
If any switch not function then change it
HP Compaq FP5315... | Answered on May 13, 2011
Make sure your computer is working properly. Hook up another known working monitor up to the computer and turn it on. If you get video on the known good monitor then that means the original monitor is bad. If you don't get video on the know good working monitor then that means the computer has no video output and the computer would need to be troubleshooted.
HP Compaq FP5315... | Answered on Mar 30, 2011
More likely to have dying power supply due to bad caps with domed tops.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP/COMPAQ monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
HP Compaq FP5315... | Answered on Feb 10, 2011
The problem lies in your ram. Pull the modules,swap their positions and reboot. The contacts are dirty and by removing them, they again make proper contact. Blow out dust. You will be fine.
HP Compaq FP5315... | Answered on Jan 23, 2011
CTRL ALT and 8 (on the numberpad.. UP arrow) Used to work on Windows XP
If you are using an NVIDIA card, in Control panel > personalise > display> Nvidia control panel, set screen to rotate
Once in there, reset the resolution of the display to something that suits you better
HP Compaq FP5315... | Answered on Jan 09, 2011
your LCD inverter is almost dead. the monitor itself actually remains on, but just goes to black each time the LCD inverter cuts out, since this is what supplies white light to the screen.
In case you wanted The FP5315 Users Guide, or 3 other HP documents for the HP FP5315 LCD Flat Panel Monitor:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=324205&
HP Compaq FP5315... | Answered on Jan 05, 2011
Yes you need a stereo jack to connect the monitor through the audio port (green hole) to the green port on your soundcard chip. You can obtain one of these from maplins or Radioshack or similar, which will be cheap. Make sure you tell them you wanta jack with stereo
HP Compaq FP5315... | Answered on Dec 30, 2010
you need to repair or replace the power supply, the blinking means that the the voltage is not constant so it can be a problem of defective capacitors: 1000uF 16 et 470uf 25V, you have to take it to professionnel technician because it is dangerous for you, there is a hight voltage inside the monitor but if you have some knewledge about electronic and hight voltage you can do it by your self.
HP Compaq FP5315... | Answered on Dec 27, 2010
It can due to unsteady DC voltages in the power supply because of the dying DC filter caps, it may get worst, I would inspect the caps first, more damages can result.
HP Compaq FP5315... | Answered on Dec 20, 2010
Please check all the pins of the VGA cable first, try this monitor with other PC to make sure it is not video card problem. Please post back.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
HP Compaq FP5315... | Answered on Oct 29, 2010
HP Compaq FP5315 15" LCD Monitor Logo
90 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
monitor keeps turning off wont even
  • Computers & Internet
