20 Most Recent
HP f1905 19" Flat Panel LCD Monitor Questions & Answers
I have hp w1907 computer monitor. After window
x2 test monitor on other pc.
if its ok we fix pC>
if the pc drops the sync lines H/V the monitor goes to sleep mode.
and tells you that.
the old monitors 2004 have timer inside,
does the OSD menu button on front of monitor work
with PC on,? it must.
OSD = on screed display from monitor brain
if yes, makes sure any menu there has the sleep timer off.
if it has it.
this monitor is old older than 2010. and has CCFL backlamps then and older.
so use flash light to see if data is on the screen if yes.
then the CCFL tubes are bad or the HV card inside dead.
yup your your service manaual
advanced OSD page clearly show the power saver clock
turn it off now.
of you cant get the OSD to work find a good PC
plug it in and turn this off below.
sevice manual google is your friend, sometimes.
Screen is dark, power button flickers green
Check then the cables. It may be loose pins on the connector or a bad cable. See if you can install the monitor on another CPU just to make sure that it is not the actual monitor has the problem.
Hp f1905 drops down
Contact HP by phone and they should help you getting another stand for your monitor.
HP f1905e tilt and Height adjustment
I figured it out! Just takes a phillips screwdriver and a 5/16" open end wrench to tighten up some nuts inside the plastic housing. The plastic housing doesn't come off with the screws, but has to be slightly pryed up to release the little plastic catches. Be careful though, you don't want to break the plastic tabs. It's ok to break maybe 1 because there are several to take up the slack. At first I thought it was the nuts that are 1/2" (there are two that are close to 2 springs. But that was just for the tilt forward and backward. Actually there are 4 nuts (5/16") that need to be tightened. Don't over tighten or it will not tilt at all. I took photos of the disassembled base. If you have skype, then skype me at "golfbob" chino hills, and I can send the pics or talk you through it. Good luck.
Where is the hpf1905 microphone
It does not have a built in microphone.
See source at PCWorld
http://www.pcworld.com/product/25298/hp_f1905.html?p=specs
Please rate my solution to show your appreciation!
Monitor went out and only
Use a flashlight and shine on your screen. Look carefully is you still see the image on the screen. If you do, this is an indication that the monitor is still working, but the backlight has failed.
A common solution with backlight-failures is to open the monitor, and look if you see any "swollen" capacitors (http://en.wikipedia.org/wiki/Capacitor_plague). If you see one you should replace it.
Only open your monitor if you know what you're doing and have basic knowledge of electronics and soldering.
My monitor goes blank after a certain period of
Hi kellbro1,
You're problem is not in the settings but in fact there's a three major parts involved for fault. First is your back light, second is your inverter board, third is your power supply. I've suspect that you're inverter board or its power supply caused this problem. If you have necessary tools and test instrument, know safety precaution in basic troubleshooting you may isolate the trouble. You have to test the inverter board by loading a two car bulb in series with it. Constant glow of light means you have a good inverter board and the backlight(lamp) need to be replaced, irregular glow of light means that you have a faulty inverter board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
