20 Most Recent
Audiovox Eddie Bauer 5" Lcd Add On Monitor Portable Questions & Answers
What are the input wires on a audiovox amp777
The Audiovox AMP777 is a 4-channel power amplifier, and the input wires will depend on the audio source you are using. Typically, the amplifier will have RCA input jacks for left and right channels, and you would use RCA cables to connect the audio source to the amplifier. Some amplifiers also have a high-level input option, which would allow you to connect speaker wires directly to the amplifier's input terminals. However, it's always best to consult the user manual or contact Audiovox support for specific wiring instructions for your amplifier model.
My cd runs but will not play the cd
Quite common problem. Repair it or replace your player if repair cost is too high. Personally, I stopped using CD players time ago: I use a mp3 player.
Red light is on and subs won't play
sounds like the amp is in protection mode. try disconnecting the subs and see it the light changes to green. if it does then the subs are your problem. if the light was allways red while it was working then the subs may be disconnected inside the box or have gone bad. try using a diffrent speaker and connect to the amp.
