20 Most Recent
Crown Ouku 7 Touch Screen 2 Din Car Stereo Dvd Player Radio Bluetooth Ipod Tvcamera Questions & Answers
Does not play some of the tracks of cds
with a tester current check if you have power in behind the stereo yellow wire and if hayn current in the red wire and if you ground if this is good some stereos have a button to reset them or just desconectael mains connector for a few minutes and connect it and if it does not have to replace your radio.
Set the clock
go to the screen where you would set the clock. touch the area for hours then below press the number which dictates what hour it is. do the same process for minutes.then you hold the check mark button for a couple of seconds. actually it wouldn't hurt to do that after setting the hour and minute..Also make sure you have all your wiring connected right. Cause the wire that operates the clock has voltage all the time this is what keeps the clock running you may want to check to make sure yours does not shut off with the key, Thank You Hope this helps
Ouku GPS/DVD Can't find navigation software
Make sure your SD Card is inserted in the GPS SD card slot properly. it is located behind the head of the unit( where you insert your DVDs) usually has red or orange tape over it. just remove it and reinstall it. Hope this helps.
How do i set up blue tooth
You will need the owners manual for it, Everry manufactur is different in the way you have to set it up. Ihate to tell you.
