20 Most Recent
Nikon Super Coolscan 5000 ED Film Scanner Questions & Answers
Coolscan 5000 with SF210
I'm sure all is well but if you have not tried VUescan or Silverfast as opposed to Nikons Util you should.
Windows 7 64 bit drivers
I use the same scanner. I heard Nikon was working on compatibilty with windows 7. They done it for vista but 32bit only. I would recommmend using Silverfast software. They have the comp. drivers for 32 and 64 bit windows 7. But it comes with a someone hefty price. I just looked on there site and its $398.00. It is a good software but pricey.
Will not recognize 5th image on negative strip
I inserted my negative holder in backwards on my Nikon 5000 35 mm scanner. Then I could get the last (5th) slide scanned. But I can not get the scanner to work on my new IMac because of no working driver. Silver Fast has no drivers for the Nikon 5000
Without changing any of my
You apparently updated your Mac and the update does not work with your Scan-software.Uninstall the software and remove everything that has to do with the scanner --- and reinstall the scan software.
Nikon SuperCoolscan 9000 B/W film
Does it have this problem with all of them? Have you tried changing resolution settings? and lastly have you tried uninstalling and reinstalling the drivers? Once I have more information I can try and assist you further.
thank you,
Lee
Scanner hangs when aquiring image in XP and doesn't save tofolder
Uninstall Nikon Scan.
Remove the Nikon folder from all Users on the C:/Users or Root Drive!
Open Regedit. Save the Registry file first before making changes to your desktop.
Delete the Nikon folder under HKEY_CURRENT_USER>Software
and HKEY_LOCAL_MACHINE>SOFTWARE.
Restart computer
Reinstall Nikon Scan
After not using my Nikon
Hello sir!
I would advise you to reinstall the software of Nikon Super Coolscan 5000 in your PC.
First of all, uninstall previous driver before installing a new one. And make sure, the scanner is disconnected from your PC before installation. You will connect the scanner via usb only when your system prompted you to connect it.
After a few years of not using it, you need first to check if the usb cable is still working good and not faulty.
You can also try other usb slot if the one you are using right now is unable to detect the scanner.
After a disk crash, I
Looks like driver compatibility issue. You should first install the chipset driver first and then try installing nikonscan again. If you can get me the make and model of your chipset, then I can find you a driver.
