20 Most Recent
Panasonic NV-DS65 Mini DV Digital Camcorder Questions & Answers
Weird noise from tape drive
That weird noise you are hearing is the mode motor trying to drive the mechanism. On these units, in order to engage play, fast forward, rewind, etc there is motor (called a mode motor) the drives the mechanism into the different "modes". There is also a mode sensing switch that tells the machine when it has reached a certain mode. What has likely happened is that the mode switch has failed for whatever reason, so the mode motor is being driven beyond the normal positions for the mechanism. The short answer is that you will probably have to have a technician look at it for you.
7/15/2016 4:15:42 PM •
Panasonic...
Answered
on Jul 15, 2016
Play video on tv
You will require the cable that came with the camera to be plugged into the TVS AV input sockets.
Al
11/22/2013 8:52:40 AM •
Panasonic...
Answered
on Nov 22, 2013
Hi There Can Someone Please Help I Have A
You will require a firewire cable.
Usually a 4 pin to 6 pin cable. 4 pin to camera 6 pin to computer, assuming you PC has a fireiwre socket.
PC computer have Movie Maker as part of the OS.
Connect with the above cable and you should be good to go.
Al
11/22/2013 8:15:53 AM •
Panasonic...
Answered
on Nov 22, 2013
Manual dew instrucciones
Use a hair dryer to blow warm air into the unit. Do not heat the unit but allow only warm air to circulate so as to remove any dew formation within the unit that must allow the unit to reset the error.
1/20/2012 12:21:00 PM •
Panasonic...
Answered
on Jan 20, 2012
I have no picture on
CCD Imager chip is defective in your camcorder that is why no live view in camera mode for fresh recordings.
CCD Imager is electronic device that converts an image into electronic signals and its necessary part of any digital camera/ camcorder, it should be replaced by technician because camcorder will take apart and soldering work is required.
Thanks.
9/5/2011 1:17:17 PM •
Panasonic...
Answered
on Sep 05, 2011
I have a problem in
Reduction gear in mechanism is dampered,so it wont drive the cassatte holder,so repelace the reduction gear
6/10/2011 7:45:39 AM •
Panasonic...
Answered
on Jun 10, 2011
There is no picture on the screen in either camera
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
4/27/2011 12:59:42 AM •
Panasonic...
Answered
on Apr 27, 2011
