20 Most Recent
Panasonic AG-DVC30 Mini DV Digital Camcorder Questions & Answers
Horizontal Lines during playback, not seen during
Hi,The sensor the takes the light and turns it into electrical bits of info has gone bad....or was bad from the start...If the camera is very new, then return it and get a replacement of your money back... don't mess with it there is nothing you can do...heatman101
9/15/2011 2:06:22 AM •
Panasonic...
Answered
on Sep 15, 2011
Panasonic AG DVC30 purchased on ebay. Getting
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair cost low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
9/14/2011 10:39:10 PM •
Panasonic...
Answered
on Sep 14, 2011
Panasonic AG DVC30. ALMOST new..only
This being a new set and if under warranty you MUST not attempt to openor tamper so as to VOID the warranty.
Now the obserrvation of the fault seems to be linked to a problem in the main processing board.
the static noise indicates that the servo or the luminance.
The fault requires that you will need a proper signal trace, use of an oscilloscope for video signal and a use of a proper service manual and Jig for looking into the board when it is disembled.
hence my request for such a fault seems that it be checked with the service center, take estimate and decide.
Sometimes a fault connection, and inter board connector, loose grounding or a improper shield, or dry soldering in the linking cords/ boards can be the reason but will require a close look with a magnification glass.
9/14/2011 6:56:52 AM •
Panasonic...
Answered
on Sep 14, 2011
My computer doesnt see my
Go to the panasonic website and see if they have any driver downloads for your model of camcorder. If they have download the driver and that may fix your problem
6/3/2011 12:51:47 PM •
Panasonic...
Answered
on Jun 03, 2011
My Panasonic DVC30 camcorder eats tapes on record
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
5/11/2011 3:39:45 PM •
Panasonic...
Answered
on May 11, 2011
AG-DVC30 showing dead areas on flip-out screen and
This is usually caused by an oxidized or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
2/16/2011 12:01:56 AM •
Panasonic...
Answered
on Feb 16, 2011
My panasonic ag dvc-30 will not power up. I have
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
10/18/2010 4:04:04 PM •
Panasonic...
Answered
on Oct 18, 2010
Problem with DV output on ag-dvc30
It is possible that you have a faulty firewire port or cable that is sending electricity through one of the pins that is not designed to handle it. If one of the six pins at one end of a cable is bent, for example, it can electrocute whatever is at the other end.
It's been a while now - did you ever get this problem solved?
8/29/2009 3:23:01 AM •
Panasonic...
Answered
on Aug 29, 2009
No elcectrical power
most likely problem is a defective power supply board in the camera. parts cost is about $250.00.
8/6/2009 12:46:22 PM •
Panasonic...
Answered
on Aug 06, 2009
